lower jeep Posted February 13, 2008 Author Share Posted February 13, 2008 ok so i havent updated lately, i got the 5 speed aisian transmission in :D , it wasnt that bad of a swap to do :cheers: , I'm starting to build a stroker motor for the truck found out the Nova leafs won't fit. :headpop: Link to comment Share on other sites More sharing options...
BIGHEEP Posted June 7, 2008 Share Posted June 7, 2008 I am bumping this to find out what springs you used up front to lower your MJ? Link to comment Share on other sites More sharing options...
Tank4L Posted June 13, 2008 Share Posted June 13, 2008 bump for pics Link to comment Share on other sites More sharing options...
lower jeep Posted July 12, 2008 Author Share Posted July 12, 2008 to answer a few question ive seen the front is lowered by a old set of Warn winch springs. i found them in Canada over 3-4 years ago brand new i don't know where you can find them at any more ive done research on these but couldnt find any thing about them. My jeep right now is half way torn apart waiting to get put back together after a new paint job it is know a bright green with a soon to been flat black hood and Dodge Duster style stripes on the sides the rear is getting air ride put onto it slowly so far i have the 8 inch c notch welded in and will be welding the 4 link in soon so the truck will lay the frame on the ground will have pics as soon as the 4 link gets put in thanks for the intrest Link to comment Share on other sites More sharing options...
Pete M Posted July 12, 2008 Share Posted July 12, 2008 Can we at least see pics of the pile of parts? :brows: Link to comment Share on other sites More sharing options...
lower jeep Posted July 18, 2008 Author Share Posted July 18, 2008 pics will be up tomarrow depending on weather have the 4 link welded in and the bag mounts and bags installed just have to air it up and push it out of the garage :D Link to comment Share on other sites More sharing options...
lower jeep Posted July 20, 2008 Author Share Posted July 20, 2008 here's some pics of my truck now aired up then aired down with bed not bolted down need to cut out the wheel wells on the bed Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 20, 2008 Share Posted July 20, 2008 can't wait to see the end results. THANK YOU for cutting the tail gate back out...i didn't like it molded in. any pics of the rear axle? Link to comment Share on other sites More sharing options...
jtdesigns Posted February 22, 2009 Share Posted February 22, 2009 That front axle won't tuck to well huh?? I like the progress so far.. Shaved, sectioned and slammed on air.... Nice..... Link to comment Share on other sites More sharing options...
mvusse Posted February 22, 2009 Share Posted February 22, 2009 I'm guessing interference between the axle and oil pan. Maybe use S10 parts or other independent front suspension. Link to comment Share on other sites More sharing options...
