jimoshel Posted November 13, 2010 Share Posted November 13, 2010 Will any of the aftermarket synthetic trans fluid be a acceptable substitute for transmissions where Chrysler specifically calls for ATF+4? Link to comment Share on other sites More sharing options...
whowey Posted November 13, 2010 Share Posted November 13, 2010 I won't comment on any other company's product. But yes Amsoil ATF will work in transmissions specifying Chryco ATF+4. But the fuel efficient ATL is not recommended. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 13, 2010 Share Posted November 13, 2010 if it's in an aw4, dex/merc plus 3 is the ONLY thing you should run in it. Link to comment Share on other sites More sharing options...
xjrev10 Posted November 13, 2010 Share Posted November 13, 2010 JeepcoMJ said: if it's in an aw4, dex/merc plus 3 is the ONLY thing you should run in it. I use amsoil in everything BUT my AW4s. Or any Chrysler trans. Link to comment Share on other sites More sharing options...
Jerry Posted November 14, 2010 Share Posted November 14, 2010 What would be the best "heavy duty towing" option for an AW4 transmission fluid. Thx Link to comment Share on other sites More sharing options...
PIKE Posted November 14, 2010 Share Posted November 14, 2010 Quote Will any of the aftermarket synthetic trans fluid be a acceptable substitute for transmissions where Chrysler specifically calls for ATF+4? http://www.redlineoil.com/product.aspx?pid=53&pcid=9 I use the c+atf in my Grand Cherokee that I am the orginal owner of. It has over 170,000 miles on it and have not had any problems with the transmission. :cheers: Link to comment Share on other sites More sharing options...
