kbusch18 Posted November 2, 2010 Share Posted November 2, 2010 ok so i understand the change from open to close i am just wondering from what basic model of jeep would you find the open system already factory installed or where would i fine parts out of a vehicle to make mine open Link to comment Share on other sites More sharing options...
mj Mike Posted November 2, 2010 Share Posted November 2, 2010 open system is the way to go. you are looking for a 1992 and up jeep cherokee 4.0l hi out put. get rid of that old presser bottle & get a over flow bottle. and 6 feet of 5/8 heater hose when u get the heater valve if u do. i do not run one or need one. this swap is worth wile and i am very happy with it .you will be to! Link to comment Share on other sites More sharing options...
Garvin Posted November 2, 2010 Share Posted November 2, 2010 I did this on my '90 XJ and it worked wonders. If you're looking at doing it correctly, you will need a bunch of parts (listed below, all from a '92). Radiator Thermostat housing Overflow bottle Heater valve Bunch of 5/8" hose (think I got 6' and it was more than enough) You don't technically need the heater valve, just posting it if you were to convert it completely. You will also need to reroute your hoses (will need to take a glance under a '92+ to see the routing, I just went to the junkyard and took pics and wrote up notes on them). If you do not reroute your hoses, you will run into the same issue I had where the pressure will push coolant out of the overflow bottle. Link to comment Share on other sites More sharing options...
88pioneer Posted November 3, 2010 Share Posted November 3, 2010 All I used was the radiator, overflow, an heater valve. I didn't need the t stat housing Link to comment Share on other sites More sharing options...
terrawombat Posted November 3, 2010 Share Posted November 3, 2010 Yea, I don't see the need for the newer style thermostat housing, which just adds an additional threaded hole for a temperature sensor. I believe the Renix-era engines had this temperature sensor in the block. Link to comment Share on other sites More sharing options...
Garvin Posted November 5, 2010 Share Posted November 5, 2010 Yea, I don't see the need for the newer style thermostat housing, which just adds an additional threaded hole for a temperature sensor. I believe the Renix-era engines had this temperature sensor in the block. When you replace the radiator, you remove the fan sensor in it (lower drivers side corner, towards the back of the radiator). The point of putting a new thermostat housing is now you're adding that sensor back in. It is also a two wire setup but you will need to splice lines in from the drivers side front corner to that sensor on the thermostat housing. When I put the sensor on, I ran to a junkyard to grab the correct pigtail and cut back as far as I can on that one. I ended up cutting after the connector (on the sensor side of the pigtail) of the RENIX style sensor and running from that, that way I'm not chopping up the main wiring harness. The sensor that you are referring to on the back of the block is the temp sensor. Link to comment Share on other sites More sharing options...
terrawombat Posted November 5, 2010 Share Posted November 5, 2010 Ah, I forgot about that sensor on the radiator. So, let me see if I have this straight. On a Renix-era vehicle, the temperature sensor on the radiator is to control the electric cooling fan (if equipped), the temperature sensor on the back of the cylinder head is for the instrument cluster gauge, and the temperature sensor on the block is for computer fuel adjustments. Link to comment Share on other sites More sharing options...
Geonovast Posted November 5, 2010 Share Posted November 5, 2010 Ah, I forgot about that sensor on the radiator. So, let me see if I have this straight. On a Renix-era vehicle, the temperature sensor on the radiator is to control the electric cooling fan (if equipped), the temperature sensor on the back of the cylinder head is for the instrument cluster gauge, and the temperature sensor on the block is for computer fuel adjustments. Correct. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted November 5, 2010 Share Posted November 5, 2010 Ah, I forgot about that sensor on the radiator. So, let me see if I have this straight. On a Renix-era vehicle, the temperature sensor on the radiator is to control the electric cooling fan (if equipped), the temperature sensor on the back of the cylinder head is for the instrument cluster gauge, and the temperature sensor on the block is for computer fuel adjustments. Yes, that's all good, BUT, the sensor that you will get at the parts store is not a temp switch. It does not, and will not control the e-fan on/off. It is only a sensor to tell the computer (on 91+ models). If you want to put the switch into a 91+ t-stat housing you'll have to buy a special temp switch from a GM vehicle. It's only a switch and sends current to the e-fan control relay at a certain temp (~215-220) and turns it off when the temp goes down. So what a RENIX has is: a. a SWITCH in the radiator (for the e-fan control) b. a SENDER, in the back of the head (for the gauge, light) c. a SENSOR, in the block, under the manifold (for the computer) I have done this mod on both my 88 4.0 and my 90 4.0, I did not replace the radiator switch for the fan, I just wired in a switch on my dash thru my e-fan control relay that I can flip on/off at will. If you want it to be automatic, you'll need to buy the right kind of switch for the fan control or it will not work. Also, I deleted the heater control valve in both rigs but the XJ (90) is not affected by the coolant constantly going thru it, but on the MJ (88) it always blows hot. So, a heater control valve (the newer type) will go into the MJ Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 5, 2010 Share Posted November 5, 2010 open system is the way to go. you are looking for a 1992 and up jeep cherokee 4.0l hi out put. 1991 and up XJ or MJ will work for this. Link to comment Share on other sites More sharing options...
mopwrd340 Posted November 5, 2010 Share Posted November 5, 2010 my son picked up a raditor one day from pick a part it was brand new never had aything run through it . it was a open system one and i took my fan sesnsor out removed a plug on the new one and the sensor screwed right in . don't know what brand it was :banana: Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 6, 2010 Share Posted November 6, 2010 A lot of replacement radiators work well for converting Renix cooling systems since they retain the fan switch bung hole. Even the aluminum single core radiator I use on my 91 has one. Link to comment Share on other sites More sharing options...
Suuperman Posted November 7, 2010 Share Posted November 7, 2010 Unless you really want or need to put in a new radiator with the filler neck on it you can do this conversion for under $50 and it requires no other sensor moving or anything. Plus when you need to replace your 'closed' radiator it's several $$ less than an open style rad. You just need to get an inline filler neck from the summit catalog and then convert your bottle to an overflow OR get an actual oveflow bottle from a junkyard. The neck will run you about $30. Cut the upper hose about 3" or so off the radiator and put it in. You may have to cut (section) a little more of the hose out to get it all lined up right. It works great. I have been running my '90 XJ like this for 6+ mos now (and we had 100* plus days here this summer) and my buddy did this on his daughter's XJ and his MJ many years ago. Both are still like this today and are working great.. I need to look at mine to remember which brand filler neck I used but I believe it has a 1.25" end on each side. it puts the filler at about the same height (maybe even slightly higher) than a '91+ filler would be so it's easy to fill etc. I can take pics if you like. Link to comment Share on other sites More sharing options...
sinkrun Posted November 7, 2010 Share Posted November 7, 2010 Pics would be great I am fighting with that plastic bottle right now and told myself I would never buy another. I would upgrade the whole system but my rads only a few years old so I do not want to buy another. I am ordering one tonight for the MJ. Link to comment Share on other sites More sharing options...
danbyrambler Posted November 8, 2010 Share Posted November 8, 2010 Superman - What PSI radiator cap are you using? I did the same thing to my MJ awhile back - 1.25 OD on both ends of the inline adapter from Summit & put the overflow bottle from an '88 Toyota 4x4 pickup by the MJs air filter housing - also put in a Prestone flushing tee - Never had any problems with the closed system, just wanted to make it easier to change the antifreeze - Thanks, RM Link to comment Share on other sites More sharing options...
Garvin Posted November 8, 2010 Share Posted November 8, 2010 When I did my conversion, I just bought a brand new overflow bottle for the open system. I believe I got it from Advance Auto for like $20 or $25. Link to comment Share on other sites More sharing options...
Suuperman Posted November 8, 2010 Share Posted November 8, 2010 I'm using a moroso water neck and cap. The cap says on it that it's a 12-16 lb cap but I believe the catalog rating was 15 psi. And I was off in my 'measurement' on where it sits inline. It's actually about 10" from the radiator. This way it will clear the battery and the hood (so it doesn't hit when you close the hood). If memory serves the neck was $29 and the cap was $9. Then the only other thing you need is an overflow bottle (or modify your closed system bottle to work as an overflow). Just make sure the filler neck you get has the overflow nipple on it Link to comment Share on other sites More sharing options...
terrawombat Posted November 8, 2010 Share Posted November 8, 2010 Thanks for those pictures. I did a quick search for in-line radiator water fill necks and found a few at Jegs and Summit. Advance Auto sells one, too, but it's plastic and I like the idea of it being aluminum. Only ones I have found are all 1.5" OD on both sides, so I'll have to double check the measurements to make sure that will fit. This seems like it would be a cheap way to get to an open system without having to remove the like-new radiator I just put in. Still need to grab a '91+ heater control valve... Link to comment Share on other sites More sharing options...
Suuperman Posted November 8, 2010 Share Posted November 8, 2010 I bypassed/deleted my heater control valve as well (it leaked). I notice no ill effects from it. My heat works fine and it doesn't make it hotter inside having the heater core always in the loop. You can use the upper heater hose (t-stat housing to firewall) and then whatever size hose the bottom heater hose is from the water pump to the firewall. it eliminates the rats nest and does away with multiple potential leaks. I know it is 'supposed' to be there but it hasn't hurt anything on mine. I did it to this XJ my '91 MJ (miss that truck) couple years ago with no ill effects there either. Link to comment Share on other sites More sharing options...
Suuperman Posted November 8, 2010 Share Posted November 8, 2010 http://www.summitracing.com/parts/MOR-63745/ Here ya go. The rad caps should be on the right side of this page. Link to comment Share on other sites More sharing options...
terrawombat Posted November 8, 2010 Share Posted November 8, 2010 Thanks for the link and, consequently, the part number for the thing. Found it on Amazon.com w/free shipping (as long as you have a Prime account, which I do). Link to comment Share on other sites More sharing options...
danbyrambler Posted November 8, 2010 Share Posted November 8, 2010 Superman - Thanks - I'm using a 18 lb stant-one with the P release lever - besides the easier anti freeze change thing I also wanted to limit the pressure in the closed systems bottle since stress cracks were the only problems I've ever had - was afraid the p bottle could/would be sucked dry if a 13 lb cap was used - RM Link to comment Share on other sites More sharing options...
sinkrun Posted November 9, 2010 Share Posted November 9, 2010 Just ordered mine, my plastic tank and that mess of hoses is coming out completely. Link to comment Share on other sites More sharing options...
Suuperman Posted November 9, 2010 Share Posted November 9, 2010 I bypassed/deleted my heater control valve as well (it leaked). I notice no ill effects from it. My heat works fine and it doesn't make it hotter inside having the heater core always in the loop. You can use the upper heater hose (t-stat housing to firewall) and then whatever size hose the bottom heater hose is from the water pump to the firewall. it eliminates the rats nest and does away with multiple potential leaks. I know it is 'supposed' to be there but it hasn't hurt anything on mine. I did it to this XJ my '91 MJ (miss that truck) couple years ago with no ill effects there either. With my 'upper heater hose' comment I meant to put int here you use one from a ZJ. It is already 'molded' (bent) and is a fairly easy fit. You will have to cut some off of it as it is too long. Link to comment Share on other sites More sharing options...
terrawombat Posted November 10, 2010 Share Posted November 10, 2010 Superman - Thanks for the tips. I got the inline radiator fill neck in the mail today. I'm going to hit the junkyard on Saturday for some things for my '92MJ and I'll see if I can grab an upper heater hose off of one of the ZJs they have in the yard. If not, I can just get some cut to length at the auto parts store for cheap. As long as you say the heater still works without the valve, that's good enough for me...the truck I'm trying to do this on has been demoted back to a full time work-truck for the time being (or until the motor finally pops because of it's ridiculously low oil pressure) so I'm not too concerned if it pumps out scorching heat, especially not with the cold weather rolling in. If I can find a '91+ heater valve at the yard in good shape, I may just grab that and the hoses, though. Thanks again. Link to comment Share on other sites More sharing options...
