Dont try this with the MJs
JOMJ87
Some of us go wheeling with a C02 tank and have zero problems reseating a bead by removing the air stem innards and using an air gun (flows more volume than a regular tire inflater).
But on the other hand, fire is cool. :D
swamper+ether+long flaming stick=tire back on bead.
Is it really that sketchy? I've never seen the consequences of this gone wrong.
well, it is an explosion too much fuel and the tire will pop, and likely throw some heavy chunks of rubber.
it's not recommended.
I've done it once on an ATV tire, no spares on an atv. I can't say I would even try it on a large swamper or something.
I worked for a tire shop and used it on semi tire and tractor tire before I started one of the guy used a little to much and it went high enough to touch a power line. The shop actually had a air pig set up with a tube on it that would release about a 125 psi all at once alot safer until some one put a potato in it and we never seen that potato again.
