Automan's Cleanout. IL/WI. NEW STUFF, NEW PRICES!!!!!
Automan2164
Just cleaned the garage and realized I have some stuff hanging around that I can live without. Prices are ball park(I don't sell things often), if you have a problem with it, make me an offer. Will not ship anything bigger than the biggest flat rate box. Pics to come.
2WD AX15 out of an '89 MJ with 120K, PO said it shifted great, I have no reason to believe otherwise. !!!!!!!!!!!!!!!!!!!!!!!!SOLD!!!!!!!!!!!!!!!!!!!!!!!!!
Bucket seats out of '89 Eliminator, Need work, but they are MJ buckets, with brackets and trim. $100 for the pair. They are pretty dirty, but I think they will clean up well. The D/S seat bolster has a tear, but can be found on early '90's XJ's also. The trim around the fold latch on the side is broken.
39295_150799198290909_100000824882082_225095_867567_n.jpg33571_150798968290932_100000824882082_225094_1482956_n.jpg
Pair of MJ brackets for buckets, with grey trim that attaches.
!!!!!!!!!!!!!!!!!!!!!!!SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Set of XJ waggy tails (solid red) $50
Renix Full guage set, $30. Small crack in the clear cover.
Engine stand (nicer one with the 4 legs, not the 3 leg tip master), $40.
H.O. front clip with all chrome, Red. Traded for it, traded it away, then it got traded back. I'll trade you for something interesting to keep the tradefest going.
That's all I have for now, I might come up with more as I sift through the archives.
All parts located in Harvard, IL, 60033.
Rob L. :cheers:
2WD AX15 out of an '89 MJ with 120K, PO said it shifted great, I have no reason to believe otherwise. $100
Interested in this, I bought the HO one Correy had, this would be an easier swap for me and it would allow me to sell the HO one.
You're welcome :clapping:
Pair of MJ brackets for buckets, with grey trim that attaches, $50.
intersted in these: what work is needed on the seats? I'd rather have a pair of drop in ready.
also, what year is the gauge out of?
Had a PM that beat you to the punch. If that falls through, you will be next in line.
Unsure of the year of cluster. I will double check when I take pics of everything.
Rob L.
Bump for pics.
Cluster wasn't in as good of shape as I thought... The lens is cracked, a tab is MIA, and I noticed the idiot light panel is cracked from being dropped at one time. While the crack on the idiot light panel would not be visible in the truck, I want to make anyone aware.
Could not find a year on it... And been awhile since I played with the cables... Forgot how to tell the speedo cable mounts apart. So I can't be sure.
Rob L. :cheers:
Are these still available? if so please pm me. I'm in WI, near La Crosse (SW part of state)
Any chance you would sell just the driver's side one??
PM pending on these, you will be the next in line.
Rob L.
Found this in the attic. I traded it for something I wanted $125 for... So I am asking $125 OBO. I have no real clue what its worth. Adjustable trackbar for XJ/MJ. Its pretty beefy. I was told you can just drill out the taper on the frame side, and bolt it up. I have seen HD bracket kits that use this type of end in conjunction with a beefy frame bracket upgrade.
Rob L.
Up Country coils, out of a '95 Cherokee, 130K, $30
Aux trans cooler, out of my '87 MJ (aftermarket), $40
Pics of the spacers, $30 a PAIR.
K&N Air filter, out of an '87 MJ. Needs a clean, but in really good shape. For full price, I'll include the cover with decal. $30.
PRICE CHANGES!!!
Trackbar $100 OBO
MJ buckets $75 OBO WILL NOT SHIP.
Waggy Tails $40
Cluster $20
Engine Stand $30
Again guys, prices ARE OBO>>> You don't like the price, but want the item, shoot me an offer.
All parts located in Harvard, IL 60033.
Rob L. :cheers:
Archived
