btm24 Posted September 24, 2010 Share Posted September 24, 2010 can any one help me out on this one, whats the point of the rear drum to disk convert? whats so bad about drum brakes? Thanks Link to comment Share on other sites More sharing options...
MjPioneer Posted September 24, 2010 Share Posted September 24, 2010 Disc brakes are generally easier to maintain, hold better under hard breaking, and have a better success rate. Drum brakes tend to fail should one small component shift. Plus if you're anything like me, replacing drums might as well be rocket science. Link to comment Share on other sites More sharing options...
Eagle Posted September 24, 2010 Share Posted September 24, 2010 For most drivers of MJs rear disc brakes actually hold no advantage. Their advantage is primarily that they shed heat faster than drums, so they are better for racing. Personally, I would never go through the expense and bother of converting perfectly good rear drums to discs for an MJ. Link to comment Share on other sites More sharing options...
johnnyc Posted September 24, 2010 Share Posted September 24, 2010 Just look at the drum brakes. They look so antiquated, like they're from the early 1900s. ;) The reason I converted to discs is for ease of maintenance, like MJPioneer said. But a properly adjusted drum brake setup will work great. Link to comment Share on other sites More sharing options...
kyleag89 Posted September 24, 2010 Share Posted September 24, 2010 I take my drums off every other oil change and get the brake dust out and re-adjust the shoes. O and my rear prop valve is disabled for better braking power. Link to comment Share on other sites More sharing options...
jpnjim Posted September 24, 2010 Share Posted September 24, 2010 (Rear) Discs: work better when covered in mud (vs drums) = more responsive brake system (since 90% of us let out drums fall out of adjustment, and that eats up brake pedal travel) You'll never have to experience the 'stuck brake drum' routine again. You'll never have to adjust your brakes again. That said, I run rear drums on everything that came with them. I absolutely HATE the internal drum E-brake ZJ's use, I actually have to over adjust our ZJ (and drag the brakes) just so the parking brake pass the yearly inspection. After inspection, I loosen the adjuster on those little tiny drums, and have the worlds crappiest parking brake for the rest of the year. My Jeeps: 98' XJ: stock 9"x2.5" rear drums that lock up the first time you hit them after it rains. (I have some 11x2.5" Mopar brakes patiently waiting for me to install them) 89' MJ: stock 10"x1.75" drums 88' MJ: Mopar 11"x2.5" drums Link to comment Share on other sites More sharing options...
Eagle Posted September 24, 2010 Share Posted September 24, 2010 Maybe it's because I grew up before anything other than commercial and military aircraft had disc brakes, but I don't think drum brakes are more difficult to service. I'd much rather do a set of shoes on a drum brake axle than do pads on a Jeep front axle. There are some newer disc (caliper) designs that allow swapping the pads without dismounting the calipers, and THAT would be easier. But the MJ doesn't have that. Link to comment Share on other sites More sharing options...
Pete M Posted September 24, 2010 Share Posted September 24, 2010 I hate cleaning mud out of my drums so that they work again. :fs1: Link to comment Share on other sites More sharing options...
mvusse Posted September 24, 2010 Share Posted September 24, 2010 Where I usually wheel is a lot of sand. Every time I went there I got sand inside the drums scraping the brake material off the shoes. Brand new brake shoes on Saturday morning, Sunday evening they were half gone. A month later I go for another weekend and they were down to the rivets. Had them replaced under warranty, and two trips later they were down to the rivets again. I converted to rear disc brakes, and 10 trips later the brake pads are noticeably thinner, but nowhere near needing replaced yet. Link to comment Share on other sites More sharing options...
btm24 Posted September 24, 2010 Author Share Posted September 24, 2010 oh ok then thanks a bunch guys for what i do theres no point. thanks a bunch :D Brandon Link to comment Share on other sites More sharing options...
