camjeep3 Posted September 19, 2010 Share Posted September 19, 2010 well running 33-35s off and on road i think its time to upgrade the steering in my mj. i was contemplating zj v8 pieces from the junk yard, but after some further thought i have decided i want a beefy setup with the bigger tres and all. so my question(s) are what material to use for rods. where do i get the tie rods. what should i look out for any tips, I'm crazy..... all that good stuff. tell me what ya know thanks guys Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 19, 2010 Share Posted September 19, 2010 You can buy DOM tubing from a steel supplier, and weld in threaded bungs from places like polyperformance, ruffstuff, diy4x, etc. This is not a cheap route to go down. Somebody sells a kit, I forget who, it was cheaper than I could buy all the TREs for... Somebody will chime in. Link to comment Share on other sites More sharing options...
wannabeMJ Posted September 19, 2010 Share Posted September 19, 2010 well you can do the same thing I did for my YJ and it's going with all 1 ton TRE's and dom tubing but you have to ream the knuckles to accept the largers TRE's keep in mind that I've done that to a dana 44 not sure 30 knuckles have enough metal to do this and at the same time go over the knuckle to give you more clearance ..........look for high steer on google there are some good site with lots of pics for it Link to comment Share on other sites More sharing options...
jpnjim Posted September 19, 2010 Share Posted September 19, 2010 Depending on how you attach the drag link to the cross over, you could end up with the dreaded "1/2 turn of dead space in the middle" of your steering. The more lift you have, the worse it is, as the drag link rotates the whole steering linkage before it pulls the wheels in one direction, then reverses the process to move the wheels in the opposite direction. Some have made up little Delron bushings to go over the TRE's, so the knuckle TRE's bottom out sooner, and cut down on the size of the 'dead spot', but it doesn't completely cure the problem. The Rugged Ridge kit is a cheap way to do this type of steering: http://www.shopjeepparts.com/heavy-duty ... -8010.html http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0473994939 but you can probably find it cheaper used, as lots of people try it, and can't live with the dead spot. If you don't have alot of lift, it might work OK for you. IMO, a better way to do a crossover would be with WJ knuckles, and custom links. Tho you have to raise up your Trac-Bar mount if you use the higher steering arm on WJ knuckles. Link to comment Share on other sites More sharing options...
88pioneer Posted September 19, 2010 Share Posted September 19, 2010 JCR has a bunch of 1 ton steering stuff. They sell it all together or sell each piece. Could be a good option for ya. http://www.jcroffroad.com/Merchant2/mer ... ry_Code=S6 Link to comment Share on other sites More sharing options...
camjeep3 Posted September 19, 2010 Author Share Posted September 19, 2010 http://www.ironrockoffroad.com/Merchant ... e=IR-SHDTR what about this... its a beefier than stock tie rod and just uses the stock tres. would i have to modify anything else. now I'm debating on keeping a simpler approach, but either way i NEED to replace all my steering ends. basically i want my truck to have tight steering. so that dead spot is a REAL turn off Link to comment Share on other sites More sharing options...
xjrev10 Posted September 20, 2010 Share Posted September 20, 2010 its expensive but beef. I have this steering on one of my XJs- http://www.quadratec.com/products/56116_200.htm and this on the other one: http://www.offroadonly.com/products/new/u-turn/ Link to comment Share on other sites More sharing options...
