SW86 Posted September 6, 2010 Posted September 6, 2010 well a split in one of my heater hoses has me at a stand still. ive looked at a few pull-a-parts but nothing really. or at least what my 88 has. ive searched and read you can upgrade the system or something. whats that about or is there a direct replacement i can buy somewhere? its the one hose that comes out of the thermostat and runs back into the firewall. help appreciated :yes:s
MjPioneer Posted September 6, 2010 Posted September 6, 2010 That guy is a 3/4 (19mm) hose. Any parts store should have it. When I replaced mine I think it set me back a whopping $3.00 at C.A.P.
johnnyc Posted September 6, 2010 Posted September 6, 2010 It's actually an 11/16" hose. But since that size is a little harder to find, 3/4" will work. I would double-clamp it. You can also use 5/8" hose, but it's a little tight. And 5/8" is the size of the other heater hose from the water pump to the firewall.
SW86 Posted September 7, 2010 Author Posted September 7, 2010 i have another hose that i got at the pull a part but didnt have one like my 88. i would rig it but theres a metal T that splits the hose into the coolant reservoir and into the firewall. I'm saying how do i go about fixing it/rigging it, whatever. the metal T isnt big enough to slide the hose over it or i would
carnuck Posted September 7, 2010 Posted September 7, 2010 Put in a '91 + XJ rad and eliminate the bottle and rubbish in the heater system except the on/off valve (you can even run without that till spring)
bigalpha Posted September 14, 2010 Posted September 14, 2010 Can you get the factory hoses anywhere? I know that each end of the hsoes are different sizes.
johnnyc Posted September 15, 2010 Posted September 15, 2010 The hose that goes from the lower outlet on the firewall to the water pump is 5/8". The hose that goes from the upper outlet on the firewall to the thermostat housing is 11/16".
PIKE Posted September 15, 2010 Posted September 15, 2010 Can you get the factory hoses anywhere? I know that each end of the hsoes are different sizes. You can get them here. Scroll about 3/4 way down the page. http://www.teamcherokee.com/Cooling/index.html Picture. http://www.teamgrandwagoneer.com/parts/ ... /1763.html
bigalpha Posted September 15, 2010 Posted September 15, 2010 Thanks. For some reason, I recall the hoses being two different sizes at each end of the hose .. e.g. from the heater core to the metal T, or the T to the t-stat.
