wannabeMJ Posted August 8, 2010 Share Posted August 8, 2010 from wiki: Jeep XJs came in several standard gearing ratios: 3.07:1, manual transmission, I6 engine. 3.54:1, automatic transmission, I6 engine with Dana 44 rear differential. 3.54:1, manual transmission, I4 diesel engine with Dana 35 rear differential. 3.55:1, automatic transmission, I6, V6 engines; manual transmission, I4 engine. 3.73:1, automatic transmission, I6, Tow Package, UpCountry Package. 4.10:1, manual transmission, V6; automatic transmission, I4 engine. 4.56:1, automatic transmission, I4, offroad or tow package. can some one confirm this for the MJ's Link to comment Share on other sites More sharing options...
Pete M Posted August 8, 2010 Share Posted August 8, 2010 rules of thumb for 87-92 MJs 4.0 + auto = 3.55 4.0 + stick = 3.07 2.5 + auto = 4.56 2.5 + 4spd stick = 3.55 2.5 + 5spd stick = 4.10 uber rare fuel economy package = 3.31s rules of thumb for 86 MJs metric ton = 4.10s beyond that, ya really gotta check to know for sure. Link to comment Share on other sites More sharing options...
wannabeMJ Posted August 8, 2010 Author Share Posted August 8, 2010 no known knowledge about the V6 2.8l gears?? Link to comment Share on other sites More sharing options...
freakjeep93 Posted August 8, 2010 Share Posted August 8, 2010 rules of thumb for 87-92 MJs 2.5 + auto = 4.56 . does this apply to xjs to? ive got the rear end out of a xj that had a carbed 2.5 with an auto tranny and 4wd. wiould it have 4.56's? Link to comment Share on other sites More sharing options...
Pete M Posted August 8, 2010 Share Posted August 8, 2010 is it 87-92? if not, then you have to check. Link to comment Share on other sites More sharing options...
freakjeep93 Posted August 8, 2010 Share Posted August 8, 2010 it had a carbed 4 cylinder so i think thats before 87? Link to comment Share on other sites More sharing options...
Eagle Posted August 8, 2010 Share Posted August 8, 2010 An XJ with the carbureted 2.5L may have 4.56s, or it may have 4.10s. Link to comment Share on other sites More sharing options...
freakjeep93 Posted August 8, 2010 Share Posted August 8, 2010 okay ill have to check sometime. only thisng is its buried under about 3 other axels in the bed of a parts mj Link to comment Share on other sites More sharing options...
Eagle Posted August 8, 2010 Share Posted August 8, 2010 I have the remains of an '86 2.8L automatic (XJ) that has 3.73 gears under it. Link to comment Share on other sites More sharing options...
wannabeMJ Posted August 9, 2010 Author Share Posted August 9, 2010 all right means Ill have to open mine up to check on this and Ill post up the results soon Link to comment Share on other sites More sharing options...
deziped Posted August 9, 2010 Share Posted August 9, 2010 Junked out a 86 w 2.8 that was auto with OE D20 rear & 4.10's. It was 2 wd. Link to comment Share on other sites More sharing options...
wyk Posted August 9, 2010 Share Posted August 9, 2010 no known knowledge about the V6 2.8l gears?? My 4X4 5spd 2.8 has 4:10's. Looks like a D35 in the back to me. Oh, btw, I am swapping the oil tomorrow, should I get a gasket from the Jeep dealer or use the goopy stuff? Link to comment Share on other sites More sharing options...
kastein Posted August 9, 2010 Share Posted August 9, 2010 rules of thumb for 87-92 MJs 2.5 + auto = 4.56 . does this apply to xjs to? ive got the rear end out of a xj that had a carbed 2.5 with an auto tranny and 4wd. wiould it have 4.56's? might, but it'll probably be a d35 so I wouldn't run it. FYI - the 20 rear axle is an AMC 20 not a D20. A D20 is a nifty twin-stickable gear driven transfer case, as I recall. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 18, 2010 Share Posted August 18, 2010 edit. its a 4.0l but still a D44 Link to comment Share on other sites More sharing options...
