I know this may not help but stock 1990 Dakota wheels will bolt up perfectly to a 1988 Comanche.
I'm running a set now until I can get my tires mounted on the Jeeps original rims.
I can only assume that you have a chance at a set of JK rims and you want to know if theyll fit your Dak, right? If I have a chance today, Ill see if I can get a measurement for you.... that is if we have one come in that needs a wheel pulled off of.
The 05 is the same as an 08 Dakota and the bolt pattern is 5x5.5 not the JK 5x5...
CJ rims will fit on your Dakota but NOT JK unless you use wheel spacer adapters...
thanks guys. it was for my bro-in-law's truck, but the tires are sold so it's all moot. :(
