aemsee Posted May 26, 2010 Posted May 26, 2010 I installed a 500 GB hard drive on my kids computer, but it still thinks it has a 40 GB drive. I did use cloning software that came with it. Any idea how to get it to realize it has 500GB? It is a Dell Optiplex 620 running XP home.Thanks
Geonovast Posted May 26, 2010 Posted May 26, 2010 Back in the day, some harddrives had jumper settings that limited the space... I doubt that's the problem, but it doesn't hurt to check. Was the harddrive you cloned from a 40GB?
Wallyman Posted May 26, 2010 Posted May 26, 2010 Look in your BIOS settings, there is usually an auto detect setting you can try. It may need you to tell it it has a new hard drive
aemsee Posted May 27, 2010 Author Posted May 27, 2010 I forget how to enter the BIOS. What is wierd is that in some places it shows 500GB, and others (like under 'My Computer" and drive 'c' properties), shows 40GB
aemsee Posted May 27, 2010 Author Posted May 27, 2010 Yes, the HD that was cloned was the original 40
freakjeep93 Posted May 27, 2010 Posted May 27, 2010 when starting th pc push DEL and it will go into bios
beepbeepmyredjeep Posted May 27, 2010 Posted May 27, 2010 I don't believe this is a BIOS problem. There is a difference between physical drives and partitions. One physical drive can contain multiple partitions When you performed your clone, you may have cloned the partition (C:), and not the physical drive. Unfortunately under Windows XP, it's not possible without 3rd party software to expand the current partition. This results in a 500 GB physical drive with one assigned partition with a size of 40 GB. The remainder of the disk remains unusable until you format it, and create an additional partition. Take a look at http://support.microsoft.com/kb/309000 You'll want to use the unallocated space to create a new (second) primary partition. You can then use the second partition to install additional programs. Just make sure when installing you specify the new drive letter.
AmJay Posted May 27, 2010 Posted May 27, 2010 I'm pretty sure you have an unpartioned 460GB of disk space. If you want to expand your current partition look for a program call GPARTED. Although designed for Linux it will expand Windows partitions. Google Gparted and you should be able to find it. Also if I remember there is a 140GB limit per partition. I'm not real sure since I don't run windows too much.
Burls Posted May 27, 2010 Posted May 27, 2010 Xp has a basic partition utility built in. Control Panel> Administrative Tools> Computer Management(Icon) -- Underneath the Storage section on the left side -- Disk Management
aemsee Posted May 27, 2010 Author Posted May 27, 2010 think I found the answer but can't try til after work. Thanks guys
Eagle Posted May 27, 2010 Posted May 27, 2010 Yes, the HD that was cloned was the original 40 The 40 gig drive had one 40-gig partition. More than likely, when you cloned the drive it cloned the partition size as well as identification. I don't remember hos to get into the partition info in the new versions of Windows -- what you're looking for is the equivalent of the old FDISK command in MS-DOS. You want to find out how many partitions your drive has and what sizes. Since you are only seeing 40 gigs, there are (I think) only two possibilities: (1) You have one 40-gig partition and a lot of unallocated space; or (2) You have one 40-gig partition and a second, 460-gig partition that needs to have a logical drive letter assigned to it and be formatted before you can use it. I believe there is a utility (but I don't recall if it's in Windows or aftermarket) to dynamically expand a partition to take up all unused, unallocated space available on the drive. Maybe Google on "Expand+Partition"?
aemsee Posted May 28, 2010 Author Posted May 28, 2010 Eagle was right. It was a disk partition issue. Tried the partition utility several different ways. Problem was that part of the computer recognized the partition as being 480+ GB, but some areas saw the old 40 GB. So when I tried to use the partition utility, it thought it was already the 480 GB part and couldn't enlarge it any more. So I just reformatted the drive and all is good now. Too bad I paid an extra $20 for the USB hard drive chassis and software over the price of the HDD. Oh well. Thanks for all your responses guys.
