wannabeMJ Posted March 24, 2010 Share Posted March 24, 2010 how much lift will grand cherokee coils will give me? I think i read before it was 4.5'' and with a SOA in the back will the truck be level? only with these mods do I have to change the UCA and LCA? I also know that the LCA from a grand cherokee are stiffer then the oem but are they longer? I know about the brakes lines YJ lines in the front and dakota 95 in the rear remember this very low budget mods lolll Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted March 24, 2010 Share Posted March 24, 2010 What type of Grand Cherokee? ZJ Coils from a V8 equipped model will give 1-1.5" lift. ZJ Coils from a non-V8 equipped model will give you no lift. WJ Coils will not fit into the XJ/MJ as the coil diameter is wrong. WK Coils will not fit into the XJ/MJ as the coil diameter is also wrong. SOA in the rear will net anywhere from 5-7" of lift based on the condition and type (2wd/4wd) of factory leafs it came with. Your going to want a 6.5" coil in the front to make it look correct. WJ control arms are no longer than your factory arms currently are. Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 24, 2010 Author Share Posted March 24, 2010 so Ill need to buy coils its not like G-cherokee coils on a TJ wow with a SOA ill need to lift the front 6.5'' so it means ill have to change the LCA and UCA ......... :wall: there goes the low budget Link to comment Share on other sites More sharing options...
Geonovast Posted March 24, 2010 Share Posted March 24, 2010 so Ill need to buy coils its not like G-cherokee coils on a TJ wow with a SOA ill need to lift the front 6.5'' so it means ill have to change the LCA and UCA ......... :wall: there goes the low budget And track bar... and sway bar links... and shocks... and brake lines... and you'll want big tires... so you'll want to regear... Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 24, 2010 Author Share Posted March 24, 2010 all ready got the sway bar and track bar will be made costum with DOM tubing will get shocks soon and for tire its a DD so ill just run 31'' I already got a YJ on 35'' Link to comment Share on other sites More sharing options...
Geonovast Posted March 24, 2010 Share Posted March 24, 2010 31"s are gonna look ridiculous on 6.5" of lift. :dunno: Link to comment Share on other sites More sharing options...
ovrszd Posted March 24, 2010 Share Posted March 24, 2010 31"s are gonna look ridiculous on 6.5" of lift. :dunno: Ridiculous is in the eyes of the beholder.... Gotta respect his attempt to stay on a small budget. Link to comment Share on other sites More sharing options...
Pete M Posted March 24, 2010 Share Posted March 24, 2010 why not less lift? :dunno: I never seem to get the general obsession with going SOA. :hmm: Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 24, 2010 Author Share Posted March 24, 2010 well Ill be stuck I was hoping for a 4 .5 lift is there a compagny that ofers a pack of leafs with lift in it without going with a SOA? or is my only option left is longer shackle ( wich i don't realy want) Link to comment Share on other sites More sharing options...
Geonovast Posted March 24, 2010 Share Posted March 24, 2010 Hellcreek. The owner is a member here on CC, and gives a discount to members. viewtopic.php?f=24&t=19998 a 4.5" lift shackle would have to be at least 10 inches longer than stock... would look horrendous and no doubt cause you a ton of problems. Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 24, 2010 Author Share Posted March 24, 2010 thanks I just gave him a call he'll call me back with the amount for the shiping for a final price gess if you wanna do a good job u don't have a choice but spend some $$$$$ Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 24, 2010 Author Share Posted March 24, 2010 well its done in a week ill be the proud owner of a 4.5'' lift kit from hell creek can't wait to put it on the truck Link to comment Share on other sites More sharing options...
Geonovast Posted March 24, 2010 Share Posted March 24, 2010 well its done in a week ill be the proud owner of a 4.5'' lift kit from hell creek can't wait to put it on the truck :clapping: Take before & after pics from the same angle in the same spot! Link to comment Share on other sites More sharing options...
Pete M Posted March 24, 2010 Share Posted March 24, 2010 Heck, take photos as you go and make a DIY write-up out of it. :D Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 24, 2010 Author Share Posted March 24, 2010 Heck, take photos as you go and make a DIY write-up out of it. :D much likely to do so Link to comment Share on other sites More sharing options...
wannabeMJ Posted April 1, 2010 Author Share Posted April 1, 2010 bringing this post back up will I have enough room to put 35'' on it with the 4.5'' lift I got a great deal for the tires who here is runing 35'' and how much lift do you have on your truck? did you trim a lot to fit them ? Link to comment Share on other sites More sharing options...
mvusse Posted April 2, 2010 Share Posted April 2, 2010 I ran 4.5" in the front for a short while running 33x12.50s and had problems with the wheel hitting either the back or front of the wheel well when steering on anything but a perfectly smooth road. I couldn't find a sweet spot in between. I then added 1.75" spacers and all was good. 33x11.50 or 33x10.50 should work. 35x12.50 will not, and I don't think there are any narrower 35s. I now run 6.25" up front (4.5" spring plus 1.75" spacers) and 35x12.50 tires. With this setup the 35s will need very aggressive bump stopping, or a LOT of cutting. Even with cutting, bump stopping is still needed to keep them from getting jammed into the wheel well. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted April 2, 2010 Share Posted April 2, 2010 I disagree with Marcel... I know it's an XJ (but hey the rear wheel openings are smaller on the XJ's); but I run 35's on 5" of lift on my XJ and 33's on 3.5" of lift on the wife's XJ. A lot goes into factor other than just lift height. Wheel width and backspacing play a major role as well. MY XJ on 35's w/5" lift Wife's XJ on 33's w/3.5" lift It's all in how you setup your suspension. Both of XJ's have a score of over 800 on a 30deg RTI ramp. Link to comment Share on other sites More sharing options...
Pete M Posted April 2, 2010 Share Posted April 2, 2010 35 inches is a lot of tire. backspacing, bumpstopping and trimming will all be very important. Link to comment Share on other sites More sharing options...
akamcbird Posted April 2, 2010 Share Posted April 2, 2010 AAAHHHHHH!!!! Pete beat me to it.... LEAD_NOT_FOLLOW what are your specs to run those 35"s (back spacing, bumpstop, what all is in ur 5" kit)? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted April 2, 2010 Share Posted April 2, 2010 LEAD_NOT_FOLLOW what are your specs to run those 35"s (back spacing, bumpstop, what all is in ur 5" kit)? Specs - http://motionoffroad.com/catalog/index. ... &chapter=0 Link to comment Share on other sites More sharing options...
wannabeMJ Posted April 2, 2010 Author Share Posted April 2, 2010 will probably have to trim a lot then............ :thumbsup: I don't have a prob with that I have a good backspacing I think 3.75 but realy not sure I just took a set of rims that I tought would be ok they look like the rims i got on my YJ ( same spacing) will post pics tommorow edit: how do i mesure the BS Link to comment Share on other sites More sharing options...
one_bad_MJ Posted April 2, 2010 Share Posted April 2, 2010 so Ill need to buy coils its not like G-cherokee coils on a TJ wow with a SOA ill need to lift the front 6.5'' so it means ill have to change the LCA and UCA ......... :wall: there goes the low budget And track bar... and sway bar links... and shocks... and brake lines... and you'll want big tires... so you'll want to regear... I'm running 33's on my truck with 3.07 gears and i still get 28 mpg straight 6 renix 5-spd my truck turns them just fine. Link to comment Share on other sites More sharing options...
Pete M Posted April 2, 2010 Share Posted April 2, 2010 And yet my 88 4.0/3.07 sucked in a major way when I went to ginormous 30" tires. :( 3.55s fixed it right up. :D Link to comment Share on other sites More sharing options...
mvusse Posted April 2, 2010 Share Posted April 2, 2010 28mpg out of a 4.0??? Link to comment Share on other sites More sharing options...
