so i was cruising on ebay and found what seems to be a fsm for all MJs on disk and want to know what you guys think about buying it and if i do i will see about hooking everyone up that might need one ;) but we will see i just want to know before i bid and please don't steal this from me. nutkick.gif thanks and let me know ASAP since it ends tommorow.
Cole
10 to much to spend or what? Do you think its good or not? jamminz.gif hard to tell if your being a smartazz or nto over the net plus I'm haveing one of those nights. :shake:
Cole
if you got 10 bucks to spare i would say go for it. you may get lucky and it might be one for an MJ. but it sounds like it is just the XJ version that he is selling as an MJ version. i have yet to find an MJ one on disc.
Alex
It probably isn't the factory manual as Pete said, but if it's 10 bucks, that's less than a Chiltons and you've probably got the engine covered and more at a far better quality. Do it !
alright I'm bidding and if its decent ill send everyone copies for the low price of shipping. :brows: ;) so we will see also if Pete and the other gurus on Manche's can take a look at it to check the info that would also be great. Ill keep you posted.
Cole
JOMJ87 -
I got two diffrent CD's from e-bay, one was listed as a Jeep Parts Manual Which is not bad, but lists just the Factory parts numbers, Good referance if anything, and runs thru Adobe and the second was listed as "Jeep Service Manual" which turn out to be a Chilton Jeep manual on CD :cry:
Both around $10, So give it a try, it might be the true Service Manual, But they sell on e-bay for 35 plus.
Keep us posted.
Dang, I wish I had got here sooner....I emailed the gent about the cd and basicly told him I was looking for something that covered all the wiring and vacuum routes and if this cd covered that stuff better than Haynes or Chiltons...he told me no so I didn't bid on it.
If it does have good stuff (FSM are scarce) I'll send over a couple a bucks if you burn me a copy as well.
:cheers:
Wayne S
:cheers:
Wayne S
Ditto
:cheers:
Wayne S
i have a fsm, but it is for a 91. not sure what others it would work for except the 92s though. if you need some diagrams i could copy the pages and send em to ya. they might help better then haynes at least.
Alex
Ill keep everyone posted on how it turns out hell 10 bucks aint that bad for info plus i can print out whats needed and use it till i can't read it thru the grease and print it again jamminz.gif so ill let you know.
Cole
