Stumpy Posted October 5, 2006 Posted October 5, 2006 Picked up my RE LCA from Asshogger today..well wednesday lol.
Stumpy Posted October 5, 2006 Author Posted October 5, 2006 Asshogger? Well, looks sweet. its a shop near STL, MO Thanks i hope they help with the DW i've got! here is there forum/site A.H. offroad
Hot Rod Jeep Posted October 5, 2006 Posted October 5, 2006 Yeah, I agree sweet and scary all at the same time. :eek: 8)
Stumpy Posted October 5, 2006 Author Posted October 5, 2006 Yeah, I agree sweet and scary all at the same time. :eek: 8) scary? :huh???:
Hot Rod Jeep Posted October 5, 2006 Posted October 5, 2006 Well, you replied right before I could and I didn't use the quote button. I was referring to "Asshogger", but you've cleared that up now. :D 8)
Stumpy Posted October 5, 2006 Author Posted October 5, 2006 :rotf: aaahh got ya...i'm buyin a "Asshogger Offroad" windshield sticker hopin it pisses my boss off.. :nanner:
Hot Rod Jeep Posted October 5, 2006 Posted October 5, 2006 You putting it on your MJ or his vehicle? :D 8)
Pete M Posted October 5, 2006 Posted October 5, 2006 its a shop near STL, MO I think that's the shop I stopped by on the way back from Moab when I needed to tweak my control arms bushings. :D
Stumpy Posted October 5, 2006 Author Posted October 5, 2006 What kind of LCA ?? RE3720 ??? no the RE3715
87manche Posted October 5, 2006 Posted October 5, 2006 what kind of setup do you have in the rear, stock packs with SOA? It seems to flex pretty nice back there.
Oizarod115 Posted October 5, 2006 Posted October 5, 2006 what kind of setup do you have in the rear, stock packs with SOA? It seems to flex pretty nice back there. I'm not lifted at all and my rear packs flex so far that my brothers 48" hilift was nearly at the top in order to get the tire off the ground (lifted from the bumper) i LOVE your manche.
Stumpy Posted October 6, 2006 Author Posted October 6, 2006 what kind of setup do you have in the rear, stock packs with SOA? It seems to flex pretty nice back there. yup. i've been keepin a look out for another good set at the local j-yard to build up as a spare.
Hot Rod Jeep Posted October 6, 2006 Posted October 6, 2006 4wd MJ springs have more arch than 2wd springs right? 8)
Stumpy Posted October 6, 2006 Author Posted October 6, 2006 4wd MJ springs have more arch than 2wd springs right? 8) ya. i got a little over 6" of lift from mine. ive heard that 2wd get about 4-4.5" IIRC. i hope that with all my trail gear the rear sags a little as it sits higher than the front without a load in the bed.
Hot Rod Jeep Posted October 6, 2006 Posted October 6, 2006 ya. i got a little over 6" of lift from mine. ive heard that 2wd get about 4-4.5" IIRC. i hope that with all my trail gear the rear sags a little as it sits higher than the front without a load in the bed. That's what I was thinking, thanks. :cheers: 8)
Stumpy Posted October 6, 2006 Author Posted October 6, 2006 took the manche out for a drive today and the DW is gone..for now..lol!!!!! it rides SOOO much better now i looked at my old "control" arms and the reason i think i had DW was because the arms would/were resting on the spring perches. :shake: :oops:
feerocknok Posted October 7, 2006 Posted October 7, 2006 took the manche out for a drive today and the DW is gone..for now..lol!!!!! it rides SOOO much better now i looked at my old "control" arms and the reason i think i had DW was because the arms would/were resting on the spring perches. :shake: :oops: Mine are hitting the shock thingy too at 4". It doesn't allow for any droop on the axle. I need a set. :cry: When's the trail test?
CWLONGSHOT Posted October 7, 2006 Posted October 7, 2006 took the manche out for a drive today and the DW is gone..for now..lol!!!!! it rides SOOO much better now i looked at my old "control" arms and the reason i think i had DW was because the arms would/were resting on the spring perches. :shake: :oops: The longer length gave you back the caster you lost when you lifted it. The new bushings better isolate harmonics, which is all DW is anyhow. That's more likely what eliminated/redused your DW.... DBL, check your toe in, if there is any hint of DW left, thats likely where you can totally eliminate it. Because of the inverted "Y" steering linkage, as you lift your toe decreases and needs to be adjusted. CA's not hitting the axle brackets, just gives ya more droop!! :brows: But its all good anyhow, right! Looks good!! CW
Stumpy Posted October 7, 2006 Author Posted October 7, 2006 The longer length gave you back the caster you lost when you lifted it. The new bushings better isolate harmonics, which is all DW is anyhow. That's more likely what eliminated/redused your DW.... DBL, check your toe in, if there is any hint of DW left, thats likely where you can totally eliminate it. Because of the inverted "Y" steering linkage, as you lift your toe decreases and needs to be adjusted. CA's not hitting the axle brackets, just gives ya more droop!! :brows: But its all good anyhow, right! Looks good!! CW when i "made" the LCA's :oops: i made the same length as the RE ones but the lack of offset at the axle made them too vertical causin them to bottom out. when you say inverted Y did you mean the stock steering? i have a Rusty's steering conversion on it (came installed on the MJ when i got it) but i need to replace the TRE though when i check my alignment.... :wrench:
