ive been looking for a small truck for a while now. already have an XJ and love it, so i thought id try a comanche out.
found a guy about two hours from me with a 92' 4.0 HO, 5 speed, 4x4. he said its an eliminator, but I'm not sure.
its lifted 3in on a crap set of 31s, but it runs, 4x4 works, and has a sticker on it good until 11/10. lots of little cosmetic stuff needs to be gone over, tranny is gonna have to be replaced, main seal leaks like crazy, rusty runners and floorboards, etc.... but it moves so I'm happy. got it for $600.
id like to eventually clean it up, lift it some more, nothin crazy, just need a battle ready beater to move wood in and goof off on the property i live on. anything i do to it is gonna have to be cheap and it'll probably take me a while, but ill eventually get it cleaned up.
here are some pics.
and my 99' daily driver XJ for fun
so in reverse ill get a knocking/jerking noise. only in reverse, forward gears seem fine.
dude i got it from told me it had a BA 10/5 in it, but... i checked online and then compared and i actually have the an AX tranny.
is there anyway to tell the difference from the AX 5 and the 15? i can't find any real distinguishing characteristics. i would assume that because its a 92' and 4X4 that it is most likely the AX15, thats what it looks like, can't find a serial plate.
the digits 10901276 are stamped on the bottom however?
anybody know anything about that?
should be AX15 unless someone put the BA10/5 in it, jeep quit using the BA10/5 partway through 1989.
the AX4&AX5 are 4cyl only transmissions
i pulled my front right fender today because its all chewed up. grill is broken too, and I'm not a big fan of the doors.
anybody got any info on swapping out the front clip for a 97+ XJ set up? i can get one at the junkyard for kinda cheap.
Whats the build date?
build date is 10/91
tried to replace the power steering pump last night. got a used one out of a 89 comanche. only found out the mounting bracket was different after getting mine off, total pain in the @$$, now i got to find another bracket somewhere.
The PS mount is different because the intake manifolds are different between the renix you got the pump from and the HO youre putting it on. If youre going to swap parts, they should come from same era as the original.
so i didnt know the pwr steering mounts were different until i pulled mine off. really annoying, but i made it work. instead of trying to hunt down one the same as mine i just cut the 89' mount down to mirror the 92' one. used an angle grinder and just chopped it. don't know if it will damage the integrity of the mount over time or not, but theres no difference now between the two, other than the chopped part.
and with the beat up fender off
i started pulling the transmission yesterday with a buddy. have it all out, but the oil pan and the clutch. need to replace my main seal as well as it leaks like crazy.
got my build sheet back
According to our records, your vehicle was equipped from the factory
with the following:
ALAP SE Decor Group
APAS Monotone Paint
BARP 90 Amp Alternator
BCDP 500 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CBAP Straight Back Bench Seat
CKAP Carpets - Floor and Cargo Area
CUMS Mini Floor Console
DBBC All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHNS Command-Trac Part Time 4WD System
DJHS Dana M30/181MM Front Axle
DMMS 3.07 Rear Axle Ratio
DRJS 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEHS Fixed Door Vent Glass
GFD Rear Sliding Window
GRZP Left Remote Mirror
GSZP Right Remote Control Mirror
GTZP Manual Remote Mirrors
HAA Air Conditioning
JAY Instrument Cluster w/Tach
JCAS 85 MPH Primary Speedometer
JHAP Var Intermittent Windshield Wipers
JJAP Cigar Lighter
LAPS Shift Indicator Warning Lamp
LBCS Glove Box Lamp
LMAS Halogen Headlamps
MBJP Black Front Bumper
MB1S Black Front Bumper
MDAP Front License Plate Bracket
MFFS Black Grille
MHAP Black Windshield Moldings
MMCS Upper Door Frame Moldings
MMGS Belt Moldings
MMKP Body Color Drip Trough Molding
NAAS Federal Emissions
NBKS EVAP Control System
NF2S 18.5 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RAFP AM/FM Cassette Radio
RCDP 4 Speakers
SBAP Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SFAS Standard Duty Shock Absorbers
SGAS Rear Shock Absorbers
SUA Tilt Steering Column
TBCS Compact Spare Tire
TBMS Tire Carrier Winch
TMWP P215/75R15 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WJHP 15X7 Aluminum Wheels
WLZC All Aluminum Wheels
XBSS Pickup Box
YAAS Build To U.S. Mkt. Specifications
Z01P Rear Spring Group I
Z65P Left Front Group XIV
Z82P Right Front Spring Group XI
Thanks again for your email.
Sincerely,
Lisa
Customer Service Representative
Chrysler Customer Assistance Center
and got the new trans cleaned up a little
so waitin on good weather and my new clutch kit to come in to finish this tranny swap.
needed a new internal slave for the trans and the thing is close to $160 from the auto parts store by itself which is just stupid. i got a sachs clutch kit, with the pressure plate, pinion gear, slave, and alignment tool for $186. gonna try to keep my master cylinder but I'm having a hard time getting the slave lines to come off.
any tips on getting the quick disconnect thing to work right? its stuck.
  • 3 weeks later...
i got the kit but the internal slave fittings are different. won't hook up out the box. the mechanic that ordered it for me is retrofitting something on there now to make it work. tired of this thing just sitting in the yard.
