It might give you a little bit, but not much. XJ leaves are shorter, and are designed to lay flat at stock height. MJ leaves have a curve to them.
If you want a 3" lift, check out Hellcreek for their leaf packs... a lift pack is much better than an AAL.
Well for what its worth when i put the 4" xj lift on my manch some 8 years ago and i put the add a leafs in the back and it sat level , infact the add a leafs are still in the truck to this day and are still working fine , i have since gone SOA aswell to net me near 9" of lift . o and the lift was made by trail master
Anyone know if trailmaster still offers this lift? I think they are called black diamond now... But I was always curious...
Rob L.
So how much lift will a Cherokee axle give Comanche, if swapped over and the perches are just moved over instead of relocated to the other side of the axle? It is something stupid like 9", or less?
The axles themselves are the same. Taking an MJ axle off the top of the springs, and putting it under is the same as removing the MJ axle, and putting an XJ axle on underneath.
These should help you:
So then, one would assume that the springs provide the same amount of lift (disregarding the AAL)?
