86 2,8L long box comanche X
well with the rain and snow we had this week I couldn"t do any work so I kept myself busy
when I took out the bench seat I kind of f*cked up my seat mount so i fixed it yesterday and installed it today
I had to cut the top part that atatch to the seat and redo it
I used an angle bar 3/16 thick and started mocking one up
here is the part that I did and the seat bracket once I've wirewheel them and painted
now a couple on the seat
and the fit test ...... like a glove
soon Ill finish the interior by replacing the dash where it belongs and putting all the interior back in
and tommorow my friend is comming to give me a hand and get the front suspension done
  • Replies 151
finaly got to put up the front suspension
and on the way did little things that I won't have to do later on
everybody said that the LCA on the diff use to hit on the metal bracket on the diff so I cut that
and the UCA use to hit underneath the arm bracket so cut that to
also out with old and in with the new
4,5'' longer
some pics on the way and with the diff out of the way
and now the truyck at new ride height
thats 25'' at the door step
today I went to wall-mart and bought myself 2 sets of speakers I wasn't quite sure if they would fit
I know the doors were 5 1/2'' but I bought 6 1/2'' and suprisingly they do
and I also bought 6x9 for the rear so I will do new bracket so fit them
I didn't have originals in the first place anyway
now I need to get a new deck
well Ive worked on the truck this weekend
almost finalised the inside of the truck and all the wiring thanks to the thread on the '' how to connect the XJ harness to the rear MJ one ''
made my life quite easy
I also installed the rear speakers and the dash
here is a couple of pics I took
that's the speaker and the bracket I made
with the dash
I saw that in an other project thread and I tought it would look nice with the black interior
and finally a shot with the passenger seat in with all the interior
  • 1 month later...
should have bought this one for my project .........but its........ gold :yes:
no its ok now the guy was in a front end crash and the grill and the fenders needed to be replaced
but I got it for 100$ and the 2.8L works good :???: I think I just robbed the poor old man I offered him 100 and he said yes
so next weekend Ill be the owner of an other MJ
that will my 4th jeep in the yard
but the next monday 2 of them are going to the JY
I'm quickly gonna part the other MJ then send it on it's way
if you want parts come to medicine hat july long weekend
(but I keep the bed) the rest is up to grab
got the other manche yesterday :beerhead:
it had a prestone leak but still made it to my place
so I got to work and started taking everything away from underneath the bed
then with the help from the girlfriend and the roommate we got the topper off
then we switch box from my truck to this one
then I went on to fix my cab corner
fixing the rocker panel first
then the actual corner
hopefully it will look nice when I finish the body work
also had a prestone leak from the waterpump gasket wich was installed 2 weeks ago :fs2:
changed it again and still had a leak
so I said f*ck it and put gasket maker instead and it worked nicely (so far)
more to come soon as its a long weekend here and I will work some more
sorry for the pics size
once again working on my truck
I bought the rubber thing to remove pinstripe and holy rubbery thing batman it work wonders
so I moved on to getting the rust out of the ''new to me'' bed and after a days work this is what's left to do
and now 4 different colors on the truck
sorry the other comanche is already at the JY it left saturday morning
it was the only way the wife let me have it (it had to go away fast so she can have her parking space)
automan dunno it think its because its the street side so receives more $#!& being park on the street
I got some work done on the MJ lately
got a lot of body done with the help of some friends
almost all the bed is done
and I started to cut the rear fenders and I kind like the look
here is some pics I took along the day
Image Not Found
Image Not Found
Image Not Found
Image Not Found
and finaly the cab corner that I replaced
Image Not Found
sorry about the giant pics photobucket doesn't seam to resize them
after the window seat is fix and the fenders are cut Ill be starting on the paint job ......
wish me luck it will the first time I'm atempting such a thing
I guess like everything else after a few hours at it I shouldn't be to bad at it
well F*CK MY LIFE as I was trying to bleed my clutch something gave out
and fluid is leaking at the bottom of the bellhousing and the dust plate
I'm strongly suspecting the slave cylindre and that was an expense I wasn't expecting :wall:
well I got a tech Q's in there
please I need some encouraging
