james750 Posted February 20, 2010 Share Posted February 20, 2010 Thinking about putting an electric cooling fan in place of the mechanical one on my MJ. I have an Aux fan already (no A/C, part of the towing/offroad package). Could I wire the new electrical fan into the cooling temp sensor that is on the side of the radiator to control it? Does that sensor even control when the aux fan comes on? Does the aux fan come on at a higher temp than the other fan? Would this be a problem? Link to comment Share on other sites More sharing options...
dasbrick Posted February 20, 2010 Share Posted February 20, 2010 All i can tell you is that the aux fan on my Cherokee had a 190 degree activation. it would lay dormant until the engine hit 190. On the MJ, i have it wired into the ignition power, so it's always on with the engine on. Link to comment Share on other sites More sharing options...
88 Beast Posted February 20, 2010 Share Posted February 20, 2010 Switch in radiator would control electric fan operation. I think it comes on about 200 deg. and off at 190 deg. I don't think I'd run just the single electric fan. Summers can get pretty warm here you know and stop and go traffic might get alitte with just the one fan. You could probably run two electric fans controlled off the radiator switch. Of course you'd have to run another relay for the second fan. Link to comment Share on other sites More sharing options...
james750 Posted February 21, 2010 Author Share Posted February 21, 2010 No way would I run just the one aux fan, that wouldn't cool anywhere near enough. Sounds like I can run a second fan off of that same switch though, with a relay. Thanks guys! Link to comment Share on other sites More sharing options...
STERLING STINGER Posted February 21, 2010 Share Posted February 21, 2010 i don't think u can just "run it into the thermo sensor" theres a specific amount of electricity running thro that wire for a reason and in my travels, one thing ive learned is to never just splice wires into others.... imho if u want to go ahead, but i would just run a seperate wire for both to a toggle or the egnition i have mine run to the ignition also, after 2 replaced thermo sensors that didnt work :dunno: pick n pulls suck sometimes Link to comment Share on other sites More sharing options...
Pete M Posted February 21, 2010 Share Posted February 21, 2010 how much you lookin' to spend? quality fans aren't exactly cheap. and what brought up thoughts of converting? any heating problems? Link to comment Share on other sites More sharing options...
james750 Posted February 21, 2010 Author Share Posted February 21, 2010 No cooling problems, it actually cools too well. I think that the factory fan is stuck on because it is always spinning (maybe the fan is just grabbing a little bit and the fan is turning with it), and the truck never gets up to 210, new thermostat didn't help. I am not sure if I want to just replace my factory fan a new mechanical fan (sounds easier right about now) or if I want to convert to a second electric fan. Is there any way to test the factory fan clutch to see if it is always locked up or if it is functioning properly? I can freely spin it with the truck off which leads me to believe it is working and just idling along with the engine running. Just trying to get the truck up to normal operating temp. I'll try aiming the laser heat gun at it while its at operating temp next time I am at work with it to see if maybe the gauge is off and the temp sensor took a crap maybe as well. :dunno: Link to comment Share on other sites More sharing options...
bpm4x4 Posted February 21, 2010 Share Posted February 21, 2010 is there enough room to put in an electric fan there?? Or is there a special one that needs to be run? Link to comment Share on other sites More sharing options...
Pete M Posted February 21, 2010 Share Posted February 21, 2010 It's a very tight fit. some thought needs to be given to clearance with the old mech fan pulley. All of my truck's mechanical fans turn all the time too. Link to comment Share on other sites More sharing options...
nhrocker Posted February 21, 2010 Share Posted February 21, 2010 I recently decided to ditch my stock belt driven fan in my 95 XJ while in there doing a bunch of other clean up stuff. I got the new fan installed (Flex a Lite Trimline series 16" fan) but didn't have a chance to wire it yet. I've been driving it for two weeks now with only the stock electric fan. I've found that during normal driving there's enough air movement through the radiator that it doesn't even get hot enough for the stock electric to kick on. The temperature hasn't been over 35 degrees out but being a 4.0 it does warm up pretty well under the hood. If I'm parked or stopped long enough for it to hot enough the electric turns on and within 30 seconds it usually cools it down enough to shut off again. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 22, 2010 Share Posted February 22, 2010 CLICKY HERE Link to comment Share on other sites More sharing options...
nhrocker Posted February 22, 2010 Share Posted February 22, 2010 CLICKY HERE I had checked out your write up over in NAXJA during my research for mine. Awesome job, I love how it came out! I ruled out using a stock fan after I couldn't find any friends with some kicking around and junkyards jacked up the price to $75 or more for one (compared to the $30 or so I paid just a couple years ago for one). For $115 I purchased a brand new aftermarket one. I also found that a stock one wouldn't even fit between the engine and radiator in mine, but that was a non-issue since I ended up moving the radiator forward to fit the aftermarket one I picked up as well. I plan on keeping an eye out for good stock fans for spares and possibly to redo mine more similar to yours, and for future rigs/projects. I like how it keeps it looking almost factory. Plus it doesn't hang down nearly as much as my 16" does, which impedes on the area I wanted to use for a hidden winch. Link to comment Share on other sites More sharing options...
