steve Posted September 30, 2006 Share Posted September 30, 2006 i need to pull the dash so i can finish my interior. does the steering colum need to be dropped to remove the dash? my haynes book is not real clear on this. also does any body know where i can get a lock for my slider window ? it has a single slider glass panel. Link to comment Share on other sites More sharing options...
GirsMJ86 Posted September 30, 2006 Share Posted September 30, 2006 i can't help you on the dash but i have a factory lock for your rear window if you want it. PM me your addy and i will send it to you. Alex Link to comment Share on other sites More sharing options...
aemsee Posted September 30, 2006 Share Posted September 30, 2006 Drop the column. Not much to it and it will make pulling the dash much easier. Link to comment Share on other sites More sharing options...
jage Posted September 30, 2006 Share Posted September 30, 2006 I've always pulled my dash bezel without dropping the column. It's a bit tight but they've always gone in and out without shattering in a million pieces (although it seems they should). Nothing but the bezel should be an issue as far down as I've ever gone. Link to comment Share on other sites More sharing options...
feerocknok Posted October 1, 2006 Share Posted October 1, 2006 I've always pulled my dash bezel without dropping the column. It's a bit tight but they've always gone in and out without shattering in a million pieces (although it seems they should). Nothing but the bezel should be an issue as far down as I've ever gone. Just be rough. She'll like it rough. Link to comment Share on other sites More sharing options...
aemsee Posted October 1, 2006 Share Posted October 1, 2006 Are you pulling the whole dash panel or just the cluster bezel? Link to comment Share on other sites More sharing options...
BrettM Posted October 1, 2006 Share Posted October 1, 2006 i can't help you on the dash but i have a factory lock for your rear window if you want it. PM me your addy and i will send it to you. Alex so that's where it is... Link to comment Share on other sites More sharing options...
GirsMJ86 Posted October 1, 2006 Share Posted October 1, 2006 i can't help you on the dash but i have a factory lock for your rear window if you want it. PM me your addy and i will send it to you. Alex so that's where it is... actually both that 88 and my 86 did not have a latch on them when i got them. i found this one in a JY for my 86 and just never put it on. and i will tell you it was a witch to get it off the window in the JY MJ. if those things don't fall off then they don't come off easy at all. i almost broke the window getting it off. if you want one there are plenty more in the JY around here, just let me know and i will pick ya one up next time. Alex Link to comment Share on other sites More sharing options...
steve Posted October 2, 2006 Author Share Posted October 2, 2006 i did pull the whole dash out so I could paint it to match the reast of my interior. I will never do that again what a PITA. Alex how much do you want for the lock. thanks for all your replies. Link to comment Share on other sites More sharing options...
PlumCrazy Posted October 2, 2006 Share Posted October 2, 2006 Thread jack...I'd like to have one of those locks as well Now back to your original program already in progress Wayne S Link to comment Share on other sites More sharing options...
jbhill Posted October 2, 2006 Share Posted October 2, 2006 take the plastic panel off the top theres some screws up there, drop the column, some bolts on the side. i got frustrated and used a hammer Link to comment Share on other sites More sharing options...
