steve
Everything posted by steve
  1. thanks guys. yea the fruity one actually had a screw sticking out of the keyless entry hole and is pretty much usless as the screw was into the electronics on the back side so I will just make do with the way it is. but thanks for the wiring locations and the rest of the info. I will post pics when I get this done. thanks again :thumbsup:
  2. 89000 on 2 wheel drive 87
  3. steve
    just rambling
    thanks yea I know what you mean about fighting city hall I had originaly tried for a 24 X 36 long but that was a definit no 6 different times. :wall: thats how I ended with 32 instead. and yes it does fill up fast.
  4. steve
    just rambling
    :banana: :banana: :banana: garage is done well the outside is still have electric to put in . 24 wide and 32 deep. now I have a place to store my toys and keeps the neighbors out . comanche at home newest member and my smallest
  5. Found 2 at a local yard sale one in fairly good shape the other kind of ugly. just needing to know what to grab for these the next time I go to u- pullit. I want to put one in my cherokee and one in my mj now that my garage is about done its time to break out the tools. All I have for these is the mounting brackets. they have a temp button as well as trip in both metric and english if that helps.
  6. Sorry to all who have responded I did post the wrong year it is a 91 and not a 95 as earlier stated I was thinking of one of my other vehicles and gave out the wrong yearas my wife just informed me.
  7. well thanks for the fast response. actually the chryco column has the sloppy tilt but I understand the tightening the tilt but the turn signal switch was broken inside the column as well by the p.o. So if I understand you then the only column I can swap with is another 91? and no Jt this 91 doesnt have the air bag. I will post pic tommarrow or wed when I have a little more time. thanks for the responses steve
  8. I just got a 1991 cherokee 4x4 runs and drives great only problem Ihave is the tilt column has a little more tilt then needed.So i went to a u pull it and all the columns that matched the 1991 all have the same lame sloppy tilt ( must be a common problem). Was just going to leave when Ifound a 1989 cherokeethat has a tilt and seems solid so I pulled it When I put the 2 side by side they look the same except the keyed switch-the 89 is gm and the 91is chryco. The chryco has 2 main wire leads as well as a single pig tail that were all connected when I pulled the column from my cherokee-however the gm has the 2 main wire leads but doesnt have the pig tail and that brings me to the question are these compatable ? If not then the gm column goes into my comanche so its not a total loss I posted this on the cherokee site as well but i seem to get answers faster here so I thought I would post it here as well. thanks Steve
  9. Just a thought - would it be possible to copy your design onto business cards ? As all but one of my magnets are gone and I think I can get it done at office depot here in town fairly reasonable . thanks Steve :USAflag:
  10. well i got around to puting one of my stickers on and also created another one steve :USAflag:
  11. I couldnt get the pick to post but click the link. Imagine how much he eats & poops!...for sure not a lap dog. Subject: World's Biggest Dog! World's Biggest Dog! This is AMAZING!!! Hercules was recently awarded the honorable distinction of World's Biggest Dog. Hercules is an English Mastiff and who has a 38 inch neck and weights 282 pounds. With "paws the size of softballs" the three-year old monster is far larger and heavier than his breed's standard 200 lbs. limit. Hercules' owner Mr. Flynn says that Hercules weight is natural and not induced by a bizarre diet. " I fed him normal food and he just grew and grew and grew..." http://urbanlegends.about.com/library/b ... st_dog.htm :USAflag: steve
  12. Just as stated above use plastic paint for the plastic parts , the vinyl and fabric paint i got from auto zone . I don't have the name at the moment but I can post it later if you want. To do your seats if I remember the label it would cover your seats but it may take more then you think to get a quality look. The burgundy head liner I covered took 4 cans and you can still see a light reddish tint if you put direct light to it. The dash is done and so far no problems with the cover I will post pics when it warms up . (no garage to work in at this time) hope this helps Steve :USAflag:
  13. I forgot to tell you mine is the red one with gray and black interior . The dash is tan in the pics but has been done in gray as well. glad to meet you Steve :USAflag:
  14. if you want to see what can be done with paint and dye . Go to introduce your comanche page and check out what I did with mine. just take your time and make sure your parts are clean first. just take pics and post them. steve. :USAflag:
  15. lol. i know what you mean there. noone at the jeep dealer i worked at drove jeeps. then i showed up driving a comanche or 2 and none of them had ever seen one. i think these things must be from a parallel universe or somthing. Alex I had the same experince as well thats how i ended up with a aftermarket rear bumper. They ordered it 3 times and each time I went to pick it up it always was a bumper from a minivan not even close . And after a short heated conversation I got my money back and went on line and found one that was close to the original . they just don't get it and never will.
  16. I had an issue like that with my truck a while back. and it turned out to be a ground wire off on the engine block. Its located on passenger side just above and to the back of the oil sending unit. I can't say thats your problem. just an idea.
  17. steve
    roll bar ???
    thanks guys this one looks like the one longshot has. I'm going to grab it Monday. thanks everyone.
  18. steve
    found on ebay
    item # (i couldnt get the link to work) 150043676318 . that truck is clean and pricy.$15 grand wow. check it out.
  19. steve
    roll bar ???
    Does anybody have a good pic of a rollbar that came with these trucks. At the pic n pull I have located one that is laying in the back of an 88 pioneer but was never bolted in to the truck for what ever reason I can have it for 20 bucks but want to make sure its right. and since its not bolted in that makes it better its in great shape.
  20. Welcome Mr. Cappa it a bout time.
  21. I just posted the pic and let everyone see that artical. I didnt think it would get this big. wow.
  22. sorry i coundnt get this any bigger its kind of a breakdown of how the mj came about for those of us who didnt know, the little yellow caption box under the truck actually states tha jeep actually purchased a Africa based ford pickup to study the only unibody pickup in existence at the time. but the title says jeep autopsy-( it should say birth of a legend) the rest doesnt matter . jp maginzine oct 2006 issue. sorry obout the pic . Steve
  23. i did pull the whole dash out so I could paint it to match the reast of my interior. I will never do that again what a PITA. Alex how much do you want for the lock. thanks for all your replies.
  24. i need to pull the dash so i can finish my interior. does the steering colum need to be dropped to remove the dash? my haynes book is not real clear on this. also does any body know where i can get a lock for my slider window ? it has a single slider glass panel.
  25. This was burgundy from a doner where can i find a lock for this 1/4 inch ply wrapped in felt it had nothing when i bought the truck bench out buckets and console in body is next some rust but not bad the bumper is after market-stealerships suck does the steering colum need to be dropped to remove the dash? My haynes book is not real clear on this. oh i forgot i did change the interior color from plain tan to a gray back with frabric paint. this was destroyed by 2 deer in 94 thankgod for bodyshops. tires and wheels bought at swap meet not the best but better then the steelies this is a work in progress but i want to keep it as close to stock as possible on the out side. thanks to all of you posting your howto's so the rest of us can do it it with less hassle.
