jpnjim Posted February 2, 2010 Share Posted February 2, 2010 I was just poking around looking for replacement shafts for the 86' Metric Ton AMC Model 20. Custom shafts shouldn't be a problem, but I was just wondering if anyone ever came across the factory replacement? Both sides were the same length, and the factory part number for the shaft itself is(was): 53001 262 The entire assembly (w/ bearings, seal, retaining plate) is: 53001 524 Last listing: OEM Catalog Item Number MSRP Core Price 53001524 $199.08 $0.00 $149.31 SHAFT AXLE REAR AXLE This item is Discontinued. What are you guys running them planning on doing if you ever twist/break a factory shaft? Link to comment Share on other sites More sharing options...
jimoshel Posted February 2, 2010 Share Posted February 2, 2010 Replace it with a D44 or Chrysler 8:35 or whatever that Chrysler unit is. I thot Metric's came with D44. Link to comment Share on other sites More sharing options...
freakjeep93 Posted February 2, 2010 Share Posted February 2, 2010 they did but in 86 (i think ) they had amc model 20s Link to comment Share on other sites More sharing options...
beaterjeep Posted February 2, 2010 Share Posted February 2, 2010 they did but in 86 (i think ) they had amc model 20s You are correct. In 1986 the MJ Metric Tonne came with the AMC M20 rear end, higher load rated leafs and coils (with an extra 'overload' leaf in rear), and generally sat about 1-2" higher than non Metric Tonne 4wd MJ's. As for replacements, I wouldn't know. I still want to swear that the '86 I had is/was a Metric Tonne, but there's no M20 in the rear, even though it sits higher, and has a factory looking extra leaf in the rear with a factory looking front coils as well. Link to comment Share on other sites More sharing options...
jpnjim Posted February 2, 2010 Author Share Posted February 2, 2010 Yeah, it was a 1986 MJ only thing. I have an AMC (71 Javelin/AMX), and it's Model 20 is the same width as XJ/MJ/TJ/ZJ rear axles (Jeeps inherited the 'AMC wide body' axle width from AMC Eagles), and I've always wondered if the MJ one piece axleshafts were the same length/interchangeable with 'wide body' AMC cars. Probably not, but I was just curious, that's all. :nuts: Link to comment Share on other sites More sharing options...
freakjeep93 Posted February 2, 2010 Share Posted February 2, 2010 they did but in 86 (i think ) they had amc model 20s You are correct. In 1986 the MJ Metric Tonne came with the AMC M20 rear end, higher load rated leafs and coils (with an extra 'overload' leaf in rear), and generally sat about 1-2" higher than non Metric Tonne 4wd MJ's. As for replacements, I wouldn't know. I still want to swear that the '86 I had is/was a Metric Tonne, but there's no M20 in the rear, even though it sits higher, and has a factory looking extra leaf in the rear with a factory looking front coils as well. we must also remember they are jeeps.... yours may have been special ordered as a sorta almost ish metric tonne or someone may have wanted some life or cargo capacity and swapped the stuff in too. only way to now for sure is to do a vin check Link to comment Share on other sites More sharing options...
beaterjeep Posted February 2, 2010 Share Posted February 2, 2010 Yeah, it was a 1986 MJ only thing. I have an AMC (71 Javelin/AMX), and it's Model 20 is the same width as XJ/MJ/TJ/ZJ rear axles (Jeeps inherited the 'AMC wide body' axle width from AMC Eagles), and I've always wondered if the MJ one piece axleshafts were the same length/interchangeable with 'wide body' AMC cars. Probably not, but I was just curious, that's all. :nuts: In my opinion, I wouldn't see why they couldn't be interchanged. As long as they're both the one piece design, and are of the same WMS to WMS. But then again, that's an uneducated guess. we must also remember they are jeeps....yours may have been special ordered as a sorta almost ish metric tonne or someone may have wanted some life or cargo capacity and swapped the stuff in too. only way to now for sure is to do a vin check Well, I don't own the truck no more, but when I did run the VIN last, it showed as a standard '86 with the D35(which it has). So it may be possible special order; the build sheet would show for sure, but I never looked for it. Sorry for the hijack Jim. Link to comment Share on other sites More sharing options...
freakjeep93 Posted February 2, 2010 Share Posted February 2, 2010 Yeah, it was a 1986 MJ only thing. I have an AMC (71 Javelin/AMX), and it's Model 20 is the same width as XJ/MJ/TJ/ZJ rear axles (Jeeps inherited the 'AMC wide body' axle width from AMC Eagles), and I've always wondered if the MJ one piece axleshafts were the same length/interchangeable with 'wide body' AMC cars. Probably not, but I was just curious, that's all. :nuts: In my opinion, I wouldn't see why they couldn't be interchanged. As long as they're both the one piece design, and are of the same WMS to WMS. But then again, that's an uneducated guess. we must also remember they are jeeps....yours may have been special ordered as a sorta almost ish metric tonne or someone may have wanted some life or cargo capacity and swapped the stuff in too. only way to now for sure is to do a vin check Well, I don't own the truck no more, but when I did run the VIN last, it showed as a standard '86 with the D35(which it has). So it may be possible special order; the build sheet would show for sure, but I never looked for it. Sorry for the hijack Jim. hmmmmmmmmmm interesting sorrey about :hijack: ill stop now Link to comment Share on other sites More sharing options...
jpnjim Posted February 2, 2010 Author Share Posted February 2, 2010 Yeah, it was a 1986 MJ only thing. I have an AMC (71 Javelin/AMX), and it's Model 20 is the same width as XJ/MJ/TJ/ZJ rear axles (Jeeps inherited the 'AMC wide body' axle width from AMC Eagles), and I've always wondered if the MJ one piece axleshafts were the same length/interchangeable with 'wide body' AMC cars. Probably not, but I was just curious, that's all. :nuts: In my opinion, I wouldn't see why they couldn't be interchanged. As long as they're both the one piece design, and are of the same WMS to WMS. But then again, that's an uneducated guess. AMC cars used 2-piece shafts (bolt together, like CJ's). I need to dig out a set of AMC shafts, and measure them. I'm thinking they were different lengths side to side, but I really can't remember. MJ M20 shafts are the same length for both sides. Link to comment Share on other sites More sharing options...
jimoshel Posted February 2, 2010 Share Posted February 2, 2010 I'm a firm believer in 'Try it an see' The absolute worse that can happen is you break something.And sometimes it works. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 2, 2010 Share Posted February 2, 2010 There are several companies that make 1 pc shafts for the CJ 20's, I'm sure if you had the right info they could have one for you, I think it would just be a matter of talking to the makers. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 2, 2010 Share Posted February 2, 2010 good luck finding a stock replacement. aftermarket is about the only thing you'd find, if you can find it. I would NOT recommend wheeling on an MJ AMC20 because the parts are hard to find. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted February 2, 2010 Share Posted February 2, 2010 I would NOT recommend wheeling on an MJ AMC20 because the parts are hard to find. I guess I'm stupid cause I swapped in an AMC20 into my wheeling MJ... Parts are not at all hard to find. They are an identical housing as a WT CJ AMC20 besides the spring perches and the 1 piece shaft. The reason the shafts are NLA is all the CJ guys bought them to put in their axles to cheaply solve the 2-piece shaft failure issues. Their is a decent amount of aftermarket parts available for them, relatively the same price as any D44 part. Link to comment Share on other sites More sharing options...
comanchedude Posted February 3, 2010 Share Posted February 3, 2010 . I would NOT recommend wheeling on an MJ AMC20 because the parts are hard to find. :huh???: Oh my.. I don't agree. it is rare that you would break a MJ-AMC20 I have never even seen one break. I don't know how may people even take extra spare rear axle shaft on the trail? it not very common to see a AMC20 or D44 rear axle break. it happens I'm sure but not very often. I run work my MJ20 hard and don't worry about it.. :cheers: Link to comment Share on other sites More sharing options...
HellCreek Posted February 3, 2010 Share Posted February 3, 2010 Superior Axle makes great replacement one-piece shafts for AMC 20 axles. We bought a set several years ago when we "spun" a hub on our CJ-7 with the two-piece factory shafts. You can contact them at their website, www.superioraxle.com. -Tom Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 3, 2010 Share Posted February 3, 2010 My point was, that parts are not nearly as available as a dana 44. if you're like alot of us, used parts are in my price range...so, if I break a shaft, I'd like to find one used and cheap. I'd also like parts stores to know what I'm talking about when I go to order parts, and get it right on the first order. it's not "stupid" to wheel on an m20...but it does suck when your only options in the unlikely event that you break a shaft is to buy brand new. Link to comment Share on other sites More sharing options...
