tjjeejeepcomanche Posted January 27, 2010 Posted January 27, 2010 My 86 2.5 Comanche is pretty sluggish, I bought it to tow our trailer, but right now it struggles up hills on its own. We noticed that the cover over the throttlebody is missing a clip, thus making the cover from the airfilter less tight - I'm guessing that this could be a reason for lack of power? It's my daily driver, and is generally sluggish at present, I've done all the usual change plugs filters etc and put redex in the tank as I think it's pretty gummed up, the guy who had it before me used it for work and I don't think it was really looked after and it's tired now! any advice / suggestions?
JeepcoMJ Posted January 27, 2010 Posted January 27, 2010 My 86 2.5 Comanche is pretty sluggish, I bought it to tow our trailer, but right now it struggles up hills on its own. We noticed that the cover over the throttlebody is missing a clip, thus making the cover from the airfilter less tight - I'm guessing that this could be a reason for lack of power? It's my daily driver, and is generally sluggish at present, I've done all the usual change plugs filters etc and put redex in the tank as I think it's pretty gummed up, the guy who had it before me used it for work and I don't think it was really looked after and it's tired now! any advice / suggestions? you have less than 100hp to the rear wheels to begin with...it's not a rocket, downshifting will be necessary on hills, and it's not exactly suited to towing a trailer much bigger than a single axle motorcycle trailer...and that's pushing it in size IMHO for that 4 banger if you're doing long hauls. -Pat
Pete M Posted January 27, 2010 Posted January 27, 2010 what trans do you have? 4speed, 5speed or auto? What size tires? Did you change the fuel filter? Another contributor to sluggishness is a plugged up catalytic converter.
tjjeejeepcomanche Posted January 27, 2010 Author Posted January 27, 2010 Oh OK, looks like an engine swap needs to go on the list of things to do then!! :rotf:
tjjeejeepcomanche Posted January 27, 2010 Author Posted January 27, 2010 what trans do you have? 4speed, 5speed or auto? What size tires? Did you change the fuel filter? Another contributor to sluggishness is a plugged up catalytic converter. No didn't change the fuel filter, put that on the weekend jobs list!... Auto torqueflite box tyres are 235 x 75 X 15 I think....
tjjeejeepcomanche Posted January 27, 2010 Author Posted January 27, 2010 Don't spose anyone has a spare throttle body cover clip they can ship to me?....or know where I can get one? TJ :brows:
Geonovast Posted January 27, 2010 Posted January 27, 2010 Go ahead and throw up a WTB thread in the classified Wanted section. :thumbsup:
tjjeejeepcomanche Posted January 27, 2010 Author Posted January 27, 2010 Go ahead and throw up a WTB thread in the classified Wanted section. :thumbsup: Is done :thumbsup:
DJM/78 Posted January 28, 2010 Posted January 28, 2010 I am a big fan of the 4.0 HO , some may disagree , however a good set of low gears in the rear will help with towing . I am rebuilding my dana 44 with 4;56 gears . IMHO , a HO with low gears makes me feel like this in my head ... :banana: . I'll have to have the doctors remove my ears , so my smile can go back further . :D
dasbulliwagen Posted January 28, 2010 Posted January 28, 2010 An 86 4cyl auto SHOULD have 4:56 gearing already. And the clip on the TB cover will not help your power situation, but will keep dirt out better. Assuming you already have 4:56 gears, and are still down on power, you may need to look into other things like a cold air intake tube, removing the engine fan and installing an electric one, throttle body spacer, new injector, new 02 sensor, maybe gut the cat converter ( as to leave the impression to others that you still have a good cat ), free flowing muffler, maybe a header as available from Clifford performance... stuff like that. Ive done all this to mine except the header, and 4:10 gears instead of 4:56. Mine went from tired dog at 336,000 miles when I got it to half way peppy driver at 343,000 miles, though mine is not an auto. If your auto trans slips too much it could be part of your problem too, though I know nothing about the auto trans in any of our trucks. If I were you, I would also have a good compression test and cylinder leakdown test done before I put too much time and effort into this truck.... an engine may be what you need after all. Good luck and let us know what you do!
tjjeejeepcomanche Posted January 28, 2010 Author Posted January 28, 2010 I am a big fan of the 4.0 HO , some may disagree , however a good set of low gears in the rear will help with towing . I am rebuilding my dana 44 with 4;56 gears . IMHO , a HO with low gears makes me feel like this in my head ... :banana: . I'll have to have the doctors remove my ears , so my smile can go back further . :D Love your "signature" ! :rotf:
tjjeejeepcomanche Posted January 28, 2010 Author Posted January 28, 2010 An 86 4cyl auto SHOULD have 4:56 gearing already. And the clip on the TB cover will not help your power situation, but will keep dirt out better. Assuming you already have 4:56 gears, and are still down on power, you may need to look into other things like a cold air intake tube, removing the engine fan and installing an electric one, throttle body spacer, new injector, new 02 sensor, maybe gut the cat converter ( as to leave the impression to others that you still have a good cat ), free flowing muffler, maybe a header as available from Clifford performance... stuff like that. Ive done all this to mine except the header, and 4:10 gears instead of 4:56. Mine went from tired dog at 336,000 miles when I got it to half way peppy driver at 343,000 miles, though mine is not an auto. If your auto trans slips too much it could be part of your problem too, though I know nothing about the auto trans in any of our trucks. If I were you, I would also have a good compression test and cylinder leakdown test done before I put too much time and effort into this truck.... an engine may be what you need after all. Good luck and let us know what you do! Thanks for all that advice, a compression test is a good idea, will work through your suggestions. :thumbsup:
Pete M Posted January 28, 2010 Posted January 28, 2010 the fuel injector is known to clog over time too.
dasbrick Posted January 28, 2010 Posted January 28, 2010 that might explain my junk high acceleration? 4th/5th gear is usually pretty turtle getting to speed, and I'm a volunteer firefighter, i need speed!
tjjeejeepcomanche Posted January 28, 2010 Author Posted January 28, 2010 the fuel injector is known to clog over time too. Yeah, been running redex injection cleaner each time I fuel the tank hopefully that's giving them a clean out
