jeeplover88 Posted January 11, 2010 Share Posted January 11, 2010 Hey guys, I'm looking to remove the Pioneer decals and side molding on my jeep. any recommendations or suggestions on how to cleanly remove? Thanks, :cheers: Link to comment Share on other sites More sharing options...
jimoshel Posted January 11, 2010 Share Posted January 11, 2010 A razor blade will remove the decals.A putty knife or a long blade knife for the molding. On the adhesive for the molding again the razor blade. Heat gun will help. If your going to paint don't worry about neatness, Just scrape 'em off. Some solvents might help but I'm not familiar with them. Link to comment Share on other sites More sharing options...
Frankdm83 Posted January 11, 2010 Share Posted January 11, 2010 They make a tool for it that goes on a drill, and is like a big eraser. It takes the decals and all the adhesive under them without scratching the paint. I got mine from a body supply store. Link to comment Share on other sites More sharing options...
SuperWade2 Posted January 11, 2010 Share Posted January 11, 2010 Here viewtopic.php?f=7&t=9379 and viewtopic.php?f=3&t=8417 this is the tool I used... http://www.mytoolstore.com/astro/astmat06.html Link to comment Share on other sites More sharing options...
jeeplover88 Posted January 11, 2010 Author Share Posted January 11, 2010 alrighty. I'll probably test it out with a heat gun next weekend. Thanks guys! Link to comment Share on other sites More sharing options...
navigator Posted January 11, 2010 Share Posted January 11, 2010 for my pin striping I just used a regular hair dryer. just get it started and heat and peel. Link to comment Share on other sites More sharing options...
Darren Posted January 11, 2010 Share Posted January 11, 2010 The magic eraser is the way to go. Link to comment Share on other sites More sharing options...
misterroadman Posted January 11, 2010 Share Posted January 11, 2010 alrighty. I'll probably test it out with a heat gun next weekend. Thanks guys! THE BEST THING TO DO IS USE THE ERASER DISC ON A DIE GRINDER TOOL.I USE IT ALL THE TIME FOR WORK, ITS AMAZING AND NO DAMAGE TO THE PAINT. THE DISC ARE ABOUT $12 EACH.YOU can't GO WRONG. Link to comment Share on other sites More sharing options...
Blue XJ Posted January 12, 2010 Share Posted January 12, 2010 They make a tool for it that goes on a drill, and is like a big eraser. It takes the decals and all the adhesive under them without scratching the paint. I got mine from a body supply store. x2 definitely the best way to go, i've used one plenty of times, they work great. Link to comment Share on other sites More sharing options...
89eliminator Posted January 12, 2010 Share Posted January 12, 2010 They make a tool for it that goes on a drill, and is like a big eraser. It takes the decals and all the adhesive under them without scratching the paint. I got mine from a body supply store. x2 definitely the best way to go, i've used one plenty of times, they work great. x3. made short work of my decals. Link to comment Share on other sites More sharing options...
