comancheman Posted September 18, 2006 Posted September 18, 2006 not sure wher to post this but whats a good price for a ford 8.8. theres a 91 explorer for sale near by for $250 the body is about as bad as my comanche but all i really want is the axle would it be cheaper just to buy the axle?
beaterjeep Posted September 18, 2006 Posted September 18, 2006 In almost any case your better off buying the entire vehicle, just in case you find out you need other parts. Plus when buying the entire vehicle, you have left over stuff to re-sell and make some money back with.
Wildman Posted September 18, 2006 Posted September 18, 2006 :agree: The whole vehicle could really pay off for only one part you need, axle, plus other parts that could be used with the axle, cables, lines ?? beaterjeep is right, you could also e-bay some parts you don't need, if you want to go that route, and in the end, you'll get what 90-150 dolllars back just for the scrap at a yard. :brows:
jbhill Posted September 18, 2006 Posted September 18, 2006 the 91 axle is a drum rear end not disc. i would crawl under the rear and read the tag, if it doesnt have an L in between the gear ratio(bottom of tag towards the bolt hole) ie 3 L 73. if its an open diff i prob wouldnt bother getting it and search for one w/ discs and a trac loc. the tag is located on the right side of the cover.
DirtyComanche Posted September 18, 2006 Posted September 18, 2006 Gotta agree with jbhill. I'd just pass it over. As a parts donor exploders are pretty useless. And it is most likely a 3.73 or 3.55 axle. I'd look around for a disk one with 4.10's and the track lock. It works decent in the light rear of the MJ. But, for $250 if you want to take the time you could part it out and make money. Fords aren't very reliable, so there's always market for the parts. That and the rear driveshaft might be useable for something.
jbhill Posted September 18, 2006 Posted September 18, 2006 more then likley its a 3.08 ratio unless its 4wd or has the towing package. the older explorers are junk IMO specailly the trans missions.
comancheman Posted September 19, 2006 Author Posted September 19, 2006 the only thing that really matters to me is axle strength i plan on runnin 4.56 gears and an OX locker anyway. any price estimates on an 8.8 from the jy since i really don't have any use for the rest of the truck? thanks
Pete M Posted September 19, 2006 Posted September 19, 2006 car-part.com can help you out with prices.
DirtyComanche Posted September 19, 2006 Posted September 19, 2006 the only thing that really matters to me is axle strength i plan on runnin 4.56 gears and an OX locker anyway.any price estimates on an 8.8 from the jy since i really don't have any use for the rest of the truck? thanks Get an isuzu 12B, or D44, both can be had with 4.56s easy. Or a toyota 8". Or, or, a D60. Or, a ford 9 third out of a truck, and a housing from a bronco.
Bounty Hunter Posted September 22, 2006 Posted September 22, 2006 Got a disc 8.8 in my MJ, 4.10 and LS, picked it up complete for $100. Deals are out there at the junkyards if you do the legwork. $300 is more common around here.
