Sub woofers
woody62
jw has anyone puts subs in there comanche? i tried putting a 10in behind my seat but i kept blowing the rubber ring out of it. the guy at the store said it was bc the sub was firing right into the back of the seat. so if you have put subs in how and where do you mount them so you don't have this problem? :dunno:
I've never even heard of that problem. :hmm:
what do you mean you kept blowing the rubber ring out of it? like are you talking the sub rubs up against the back of the seat and wears on the surround? what kind of sub is it? what are you using to power it? most of the times if you have riped or cut surrounds it is because something interfered with it and damaged it or because it was rubbing and wearing down. what kind of box do you have it in? best would be a truck box it is angled so it will fit behind a seat. if you are still having problems you may have you seat to far back and will have keep it pulled forward so not to interfere with the movement of the sub.
suggestions would be see if you can get a truck box to fit without having any rubbing, make a custom sub box, or get another sub like a bass tube or other like it.
i have a 10" firing DIRECTLY into the back of my passenger seat (rubbing right on it) free junky MTX a buddy gave me years ago and it's doing just fine...
i'm only running about 400w max to it and i doubt it ever sees 200 peak so maybe thats why mine hasn't torn up, but you should be able to get a good sub with a protector or ring around it and not have any trouble.
