pigneguy Posted July 2, 2021 Share Posted July 2, 2021 On 12/10/2009 at 6:40 AM, shelbyluvv said: Firmly grasp the ignition lock... /uploads/archive/0142361112214ac544e215a033b7f85b/b094df66aed6844977f397076dd0f215.jpg And pull to the right. /uploads/archive/0142361112214ac544e215a033b7f85b/301a5541a5616f825dcc0dbdfa066001.jpg Now you have your lock out. What about getting the steering wheel to unlock or starting the Jeep until the replacement parts are procured? Well, me being the impatient one that I am I broke the plastic cover on the column. The rod that controls the steering lock and ingition switch is right there. You can accomplish the next step without busting your column up. It just has to be done from under the dash. Grab the rod and push it forward. /uploads/archive/0142361112214ac544e215a033b7f85b/9b17b60fa721a60d9cccac78eac2f9bf.jpg Here you can see the steering wheel lock engaged (pointed thing at the top of the column) /uploads/archive/0142361112214ac544e215a033b7f85b/090f7f313435fddaae9eedd76319f305.jpg And here it is released. /uploads/archive/0142361112214ac544e215a033b7f85b/5c3652cd54b3f0ef7452c7a91175f419.jpg Reassemble everything in reverse order and you will be able to start and drive your Jeep without a key. This is not suggested but if you are in a bind this will get you out of it rather quickly Regarding the steering wheel lock, when it's engaged, the ignition is off, and vice versa, when its released ignition is on ? The reason i ask is the metal tab that runs along the plastic cog behind it broke off, steering lock pin doesnt move. I'm trying to remove the ignition cylinder. there's no retaining screw to hold the cylinder in and i can't find any circlip, yet i can't pull the cylinder out. Should the steering lock be released and ignition on ...in order to pull ignition cylinder out ? Link to comment Share on other sites More sharing options...
jdog Posted July 2, 2021 Share Posted July 2, 2021 6 hours ago, pigneguy said: Regarding the steering wheel lock, when it's engaged, the ignition is off, and vice versa, when its released ignition is on ? The reason i ask is the metal tab that runs along the plastic cog behind it broke off, steering lock pin doesnt move. I'm trying to remove the ignition cylinder. there's no retaining screw to hold the cylinder in and i can't find any circlip, yet i can't pull the cylinder out. Should the steering lock be released and ignition on ...in order to pull ignition cylinder out ? Yes the key should be in the on position to remove the key cylinder Link to comment Share on other sites More sharing options...
pigneguy Posted July 2, 2021 Share Posted July 2, 2021 5 hours ago, jdog said: Yes the key should be in the on position to remove the key cylinder If the metal tab, that operates when the plastic cog is turned with the key, is broken, is there a chance that the ignition is not turned on ? And is there a way to turn the ignition on manually on the ignition switch lower down on the steering column? If so, anything to watch out for ? Link to comment Share on other sites More sharing options...
jdog Posted July 2, 2021 Share Posted July 2, 2021 Yes and yes, you will have to pull the ignition switch off the side of the column and move the rod Link to comment Share on other sites More sharing options...
pigneguy Posted July 3, 2021 Share Posted July 3, 2021 9 hours ago, jdog said: Yes and yes, you will have to pull the ignition switch off the side of the column and move the rod I assume this is what i'm meant to find but i don't see the slider on mine: Link to comment Share on other sites More sharing options...
jdog Posted July 3, 2021 Share Posted July 3, 2021 You will have to unbolt that white and black switch, it is attached with the same bolt but on the other side of the column Link to comment Share on other sites More sharing options...
pigneguy Posted July 3, 2021 Share Posted July 3, 2021 1 hour ago, jdog said: You will have to unbolt that white and black switch, it is attached with the same bolt but on the other side of the column this bolt ? IMG_0395.HEIC but the other side of the column is obscured by more wires IMG_0397.HEIC Link to comment Share on other sites More sharing options...
pigneguy Posted July 3, 2021 Share Posted July 3, 2021 14 hours ago, jdog said: You will have to unbolt that white and black switch, it is attached with the same bolt but on the other side of the column realised what you meant and got the switch off but doesnt have 4 positions of slide just 2.... and rod fell out. IMG_0406.MOV Link to comment Share on other sites More sharing options...
jdog Posted July 3, 2021 Share Posted July 3, 2021 yep thats the high beam switch, the wires are connected to the ignition switch on the other side of the column. it might be easier to see if the column is dropped Link to comment Share on other sites More sharing options...
pigneguy Posted July 5, 2021 Share Posted July 5, 2021 you said "Yes and yes, you will have to pull the ignition switch off the side of the column and move the rod" i've unbolted the ignition switch and tried moving the rod into the start position but it doesnt want to stay. Am i doing something wrong ? Also, i've tracked down the metal tab that was broken, its a rack and sector gear, i imagine i'm going to have to disassemble the whole column and remove the collar to install a new one ? Link to comment Share on other sites More sharing options...
jdog Posted July 5, 2021 Share Posted July 5, 2021 That's the ignition switch that you pictured. I took pictures of the column dissection and believe it has all the pictures Link to comment Share on other sites More sharing options...
pigneguy Posted July 5, 2021 Share Posted July 5, 2021 thanks for the link. And yep, thats the ignition switch. Can get the rod to move but it won't stay. Link to comment Share on other sites More sharing options...
acfortier Posted November 28, 2021 Share Posted November 28, 2021 Followed this, but can't seem to get my ignition cylinder out. Is there something I'm missing? The FSM says to take out the buzzer piece (two copper contacts + white plastic) but that doesn't seem to want to come out either. I've tried turning the ignition to ACC, ON, etc. and it doesn't want to budge. This is mentioned in the FSM, but I don't see anything? Link to comment Share on other sites More sharing options...
acfortier Posted November 28, 2021 Share Posted November 28, 2021 OK, figured it out--this was the piece that you have to hold down with a thin screwdriver. Link to comment Share on other sites More sharing options...
kentsu66 Posted February 14, 2024 Share Posted February 14, 2024 JFYI, if anyone else landed on this topic (great photos and step-by-step!) but needs to disassemble a non-tilt column further (e.g., to replace the wiper switch), my brother @jamespwsullivan found this video to be very helpful: CHEVROLET STEERING COLUMN REPAIR | Ignition, Dimmer and Wiper Switch Replacement! --Kent Link to comment Share on other sites More sharing options...
