RLCollins Posted December 8, 2009 Share Posted December 8, 2009 what size tires can I turn on a Dana 30? What would it take to make it stronger? What would you recommend for now, until I have the funds to do the Dana 44 and 60, what about how wide these axle are in comparison to the stock Dana 30, 35 What about axle over spring to raise it up? What kind of tires do you recommend for all around use meaning off and on road, on stock rims? The Vehicle Production Broadcast form states P225/75/ R15 OWL whatever that means - sound like a bird that flies at night to me? How do you translate the vin number? 1J7FJ36L1KL545620? would you understand this? or where is the best place to locate the Chrysler language They say the Paint is APA PQ9 QQ9 whatever that is? :ack: Link to comment Share on other sites More sharing options...
jpdocdave Posted December 8, 2009 Share Posted December 8, 2009 what size tires can I turn on a Dana 30?What would it take to make it stronger? What would you recommand? What about axle over spring to raise it up? What kind of tires do you recommand for all around use meaning off and on road, on stock rims? The Vehicle Production Broadcast form states P225/75/ R15 OWL whatever that means - sound like a bird that flies at night to me?How do you translate the vin number? 1J7FJ36L1KL545620? would you understand this? or where is the best place to locate the Chryler lauguage They say the Paint is APA PQ9 QQ9 whatever that is? :ack: i'm only gonna touch one of those on that list, OWL means Outlined Whitle Letters, on the tires. Link to comment Share on other sites More sharing options...
SuperWade2 Posted December 8, 2009 Share Posted December 8, 2009 what size tires can I turn on a Dana 30?What would it take to make it stronger? What would you recommand? What about axle over spring to raise it up? What kind of tires do you recommand for all around use meaning off and on road, on stock rims? The Vehicle Production Broadcast form states P225/75/ R15 OWL whatever that means - sound like a bird that flies at night to me? How do you translate the vin number? 1J7FJ36L1KL545620? would you understand this? or where is the best place to locate the Chryler lauguage They say the Paint is APA PQ9 QQ9 whatever that is? :ack: 35's on a D30 is not uncommon, Chromoly Axle Shafts Help...you can up the Spline count to 30spline that could also help. Some folks buld or buy axle truss's to help with the strength of the axle tubes themselves (I bent the tubes on my TJ Dana 30) Link to comment Share on other sites More sharing options...
WBKrazy Posted December 8, 2009 Share Posted December 8, 2009 what size tires can I turn on a Dana 30?What would it take to make it stronger? What would you recommend for now, until I have the funds to do the Dana 44 and 60, what about how wide these axle are in comparison to the stock Dana 30, 35 What about axle over spring to raise it up? What kind of tires do you recommend for all around use meaning off and on road, on stock rims? The Vehicle Production Broadcast form states P225/75/ R15 OWL whatever that means - sound like a bird that flies at night to me? How do you translate the vin number? 1J7FJ36L1KL545620? would you understand this? or where is the best place to locate the Chrysler language They say the Paint is APA PQ9 QQ9 whatever that is? :ack: spring over axle will give you roughly 5in. of lift in the rear. i like the toyo open country a/t's, theyre a little pricey but well worth it.. mine currently has dunlops on it cause thats what came with the wheels i bought, but when they wear out i'll be replacing them with the toyo's ran your VIN thru a decoder.. this is what it comes up with..... Position Symbol Name Value 1 1 Country : USA 2 J Manufacturer: Jeep (USA) 3 7 Type: TRUCK 4 F GVWR (Gross Vehicle Weight Rating ) : 1819-2272 kg 5 J Model: Cherokee - 4WD 6 3 Series: PIONEER 7 6 Body type Comanche, 2-door pick-up 8 L Engine 4,0 litres, I-6 9 1 Control digit: Has passed check 10 K Year: 1989 11 L Plant: Toledo #1 12-17 545620 Serial number 545620 not sure about the paint code, what color is it? i believe autozone has touch up paint listed under the codes, they can look it up in their computer.... Link to comment Share on other sites More sharing options...
garyindiane Posted December 8, 2009 Share Posted December 8, 2009 I run the toyo open country AT. I like it a lot and the price was ok. 4.5 in 265/75/16 Image Not Found Here is a vin decoder http://www.comanchemj.1hwy.com/custom3.html -Gary Link to comment Share on other sites More sharing options...
Philistine Posted December 8, 2009 Share Posted December 8, 2009 What size tires can I turn on a Dana 30? 35's at the max. But you will also want to look into regearing the axles to. What would it take to make it stronger? Chromolly axle shafts, larger ujoints, trusses to support the axle. What would you recommend for now, until I have the funds to do the Dana 44 and 60, Run what you have till you break it or can afford to replace it. what about how wide these axle are in comparison to the stock Dana 30, 35 IDK Depends on the donor vehicle. What about axle over spring to raise it up? It'll net you about 5". You'll need to do a lift for the front at the same time. I'm running a RE 5.5" up front with the SOA. What kind of tires do you recommend for all around use meaning off and on road, on stock rims? Goodyear MTRs. The Vehicle Production Broadcast form states P225/75/ R15 OWL whatever that means - sound like a bird that flies at night to me? What was the question? How do you translate the vin number? 1J7FJ36L1KL545620? would you understand this? or where is the best place to locate the Chrysler language http://www.comanchemj.1hwy.com/custom3.html They say the Paint is APA PQ9 QQ9 whatever that is? :ack: Hit up Napa, they can proably figure out what paint you need. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted December 8, 2009 Share Posted December 8, 2009 what size tires can I turn on a Dana 30?What would it take to make it stronger? What would you recommend for now, until I have the funds to do the Dana 44 and 60, what about how wide these axle are in comparison to the stock Dana 30, 35 What about axle over spring to raise it up? What kind of tires do you recommend for all around use meaning off and on road, on stock rims? The Vehicle Production Broadcast form states P225/75/ R15 OWL whatever that means - sound like a bird that flies at night to me? How do you translate the vin number? 1J7FJ36L1KL545620? would you understand this? or where is the best place to locate the Chrysler language They say the Paint is APA PQ9 QQ9 whatever that is? :ack: Here is the info Chrysler has available for your truck. Many of the codes have been recycled into their modern vehicles so they may be incorrect for your application. Hope this helps you out! Selling Dealer: 23994 - FERMAN JEEP CHRYSLER Sales Type: 1 - DIRECT RETAIL City: TAMPA State/Province: FL Country: USA Telephone: (813)253-2100 Year/Model: 1989 JEEP COMANCHE PIONEER Last Odometer: 0 Miles on Body Style: MJJM62 In-Service Date: Engine: ERB-DESCRIPTION NOT AVAILABLE In-Service Odometer: 0 Miles Transmission: DDX-5-Speed HD Manual Transmission Odometer Type: Miles Color 1: PQ9-DESCRIPTION NOT AVAILABLE Car Line: XX Color 2: QQ9-DESCRIPTION NOT AVAILABLE Build Date: February 22, 1989 Current Market Register: Hour: 08 APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKAS Carpets - Floor and Cargo Area CSRS Passenger Assist Handles CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS Dana M30/181MM Front Axle DMMS 3.07 Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GNAS Rear View Day/Night Mirror JAAS Instrument Panel JBDS DESCRIPTION NOT AVAILABLE JCAS 85 MPH Primary Speedometer JJAS Cigar Lighter JKBS Inst Panel Mounted Hood Release KKES DESCRIPTION NOT AVAILABLE K2XS DESCRIPTION NOT AVAILABLE K3CS DESCRIPTION NOT AVAILABLE LAFS Key in Ign/Seat Belt Warning Buzzer LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS DESCRIPTION NOT AVAILABLE LMAS Halogen Headlamps MBJS Black Front Bumper MB1S Black Front Bumper MFGS Body Color Headlamp Bezels MHAS Black Windshield Moldings MMCS Upper Door Frame Moldings MMGS Belt Moldings MMKS Body Color Drip Trough Molding NAAS Federal Emissions NBAS DESCRIPTION NOT AVAILABLE NBKS EVAP Control System NDAS Catalytic Converter NF5S DESCRIPTION NOT AVAILABLE QQ9S DESCRIPTION NOT AVAILABLE SBAS Power Rack and Pinion Steering SCES 2-Spoke Soft Feel Steering Wheel SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 166S Zone 66-Orlando Optional Equipment Code Description Code Description Code Description *X1 DESCRIPTION NOT AVAILABLE - Q8 DESCRIPTION NOT AVAILABLE ADA Light Group ADB Protection Group ADH Heavy Duty Electrical Group ADLA Skid Plate Group ALN Spring Special White Appearance Grp BA1P DESCRIPTION NOT AVAILABLE BCYP DESCRIPTION NOT AVAILABLE CBAP Straight Back Bench Seat CLAP Front Floor Mats DBBC All Manual Transmissions DDX 5-Speed HD Manual Transmission EAAC All Engines EAFC DESCRIPTION NOT AVAILABLE ERB DESCRIPTION NOT AVAILABLE GEC Front Left Side Sliding Window GFDA Rear Sliding Window GNBP Driver Side Illuminated Sun Visor GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors HAA Air Conditioning JAYA Instrument Cluster w/Tach JGBP Digital Clock JHAA Var Intermittent Windshield Wipers LAJP Headlamps On Warning Chimes LBBP Courtesy Lamps LBDP Ash Tray Lamp LBEP Cigar Lighter LDHP U/Hood, Removable/Rechargeable Lamp LHDP Headlamp Off Time Delay LPEP Cargo Lamp MCAP Front Bumper Guards MMPP DESCRIPTION NOT AVAILABLE PQ9 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RABA AM/FM Radio RCDP 4 Speakers TAAC All Tires TAEA DESCRIPTION NOT AVAILABLE TBBA Full Size Spare Tire TRN P225/75R15 OWL Wrangler AT Tires WJM 15X7.0 Chrome Wheels XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate YGBA 1 Additional Gallons of Gas YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z86P Right Front Spring Group XV 4EA Sold Vehicle 4HC Special Scheduling Condition III 5AMA Largo Tracking 5KNA Metro Cars of Detroit Link to comment Share on other sites More sharing options...
RLCollins Posted December 9, 2009 Author Share Posted December 9, 2009 Thanks for all this information. It will take a bit of time to look through it all. but thanks again. Link to comment Share on other sites More sharing options...
