jimoshel Posted December 6, 2009 Posted December 6, 2009 Place a peice of regular bond paper, no toilet or newsprint or light cardboard, over the axle and under the frame. Start loading the box. When the paper cannot be moved without tearing throw on another 100 lbs. That's the vehicle gross wt load. :chillin:
Eagle Posted December 7, 2009 Posted December 7, 2009 Place a peice of regular bond paper, no toilet or newsprint or light cardboard, over the axle and under the frame. Start loading the box. When the paper cannot be moved without tearing throw on another 100 lbs. That's the vehicle gross wt load. :chillin: That might be the net cargo load, or carrying capacity, but that number is available from factory specs and has been posted on this site several times. That is NOT the GVW, or Gross Vehicle Weight. GVW is the total combined weight of the vehicle and the cargo.
jpdocdave Posted December 7, 2009 Posted December 7, 2009 :huh???: sounds like he's saying load the jeep untill a peice of paper doesn't fit between the axle and bump stop add 100 pounds and you're done :nuts: and eagle is right about gvw.
jimoshel Posted December 7, 2009 Author Posted December 7, 2009 YEP ! Gotta lay off the JD when I'm tryin to be technical.
Eagle Posted December 7, 2009 Posted December 7, 2009 sounds like he's saying load the jeep untill a peice of paper doesn't fit between the axle and bump stop add 100 pounds and you're done Let's take a poll: Who still has any bump stops left?
Geonovast Posted December 7, 2009 Posted December 7, 2009 sounds like he's saying load the jeep untill a peice of paper doesn't fit between the axle and bump stop add 100 pounds and you're done Let's take a poll: Who still has any bump stops left? I do! I do! The PO on my 4.0 replaced one of them, and I have like 4 sitting in the shed.
jpnjim Posted December 7, 2009 Posted December 7, 2009 sounds like he's saying load the jeep untill a peice of paper doesn't fit between the axle and bump stop add 100 pounds and you're done Let's take a poll: Who still has any bump stops left? All my good ones are in a box in the basement. :D Even one of the 1998 XJ's rusted off after 3, or 4 years.
whowey Posted December 7, 2009 Posted December 7, 2009 sounds like he's saying load the jeep untill a peice of paper doesn't fit between the axle and bump stop add 100 pounds and you're done Let's take a poll: Who still has any bump stops left? I have one.. the other rusted off.
cracker Posted December 7, 2009 Posted December 7, 2009 The beauty of the desert is I have both of mine :D
Eagle Posted December 7, 2009 Posted December 7, 2009 The beauty of the desert is I have both of mine :D It's not considered polite to gloat ...
cracker Posted December 8, 2009 Posted December 8, 2009 The beauty of the desert is I have both of mine :D It's not considered polite to gloat ... True. :wavey:
deziped Posted December 8, 2009 Posted December 8, 2009 Mine don't look like they have ever been bumped. Hmmm, maybe if I run over the curb.
