ECU Location
The ECU is located underneath the instrument panel between the steering column and heater A/C housing. The ECU is mounted to a bracket by three screws :thumbsup:
That's for 1986 thru 1990. The 91 and 92 have the ECU next to the air intake box on the inside of the left front fender.
  • 12 years later...
4 hours ago, MJCTom said:
Where is the test connections for the SMEC or ECU on a 1988 Comanche ?
Whew....just a  little duty of a thread.
Are you refereeing to an OBD style connector? If so Renix doesn't have that. Only option is a REM from nickintimefilms.
Under the Renix relay cover by the right fender. You can use a Snapon scanner with the proper adapter also
