stageman Posted November 11, 2009 Share Posted November 11, 2009 I am re-starting my 88 Comanche build. I can post the progress in the build-up place if anyone is interest. My question is, I'm doing a 4" or so lift. I already have enough stuff to to a Add A Leaf/Shackle lift in the rear. I am not opposed to the SOA though because I am an experienced welder with a welder. Which way do I need to go? What do I need to come up with (besides perches) for the SOA. Any help, ideas, opinions would be great......Thanks Link to comment Share on other sites More sharing options...
89eliminator Posted November 11, 2009 Share Posted November 11, 2009 if your doing 4" up front, then i would go with a full leaf pack from hellcreek for the rear. either the 3" of 4.5" they have. going SOA will net around 5" to 6" Link to comment Share on other sites More sharing options...
stageman Posted November 12, 2009 Author Share Posted November 12, 2009 Well that would be nice but I don't want to spend anymore money. I can do all with existing stuff. I have a add a leaf and shackle for the rear or I can SOA. Which of these should I do? I also have some pucks to go with the 4.5" springs for the front if needed. THanks Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 12, 2009 Share Posted November 12, 2009 Well that would be nice but I don't want to spend anymore money. I can do all with existing stuff. I have a add a leaf and shackle for the rear or I can SOA. Which of these should I do? I also have some pucks to go with the 4.5" springs for the front if needed. THanks add-a-leaf plus shackle to get to 4.5" will put your pinion angle WAAAAYYYY off, so regardless youre gonna have to do some perch welding. put a cherokee shackle on it, then spring-over. it should only sit maybe 1" higher in the back then. dump the AAL's...they're junk. sell the shackles. Link to comment Share on other sites More sharing options...
stageman Posted November 12, 2009 Author Share Posted November 12, 2009 Cool man....Thanks I'd love to put in an 8.8. I don't want to re-gear (not knowing what I'm running now) unless I can find a matching ratio. Wonder what else would be needed for that? Link to comment Share on other sites More sharing options...
jpnjim Posted November 12, 2009 Share Posted November 12, 2009 My MJ rear is probably sitting between 3.5" & 4" right now, SOA, with flatter XJ leafs swapped under the MJ main leaf. MJ main leaf probably isn't too happy running this flat, but :dunno: really. I have another set of leafs that gave me ~5" SOA, those will probably go in after I get things sorted, registered, and get my first inspection sticker in 5-6 years (the first sticker is always the toughest, so I want to go in as low & "safe" looking as possible) Link to comment Share on other sites More sharing options...
akamcbird Posted November 12, 2009 Share Posted November 12, 2009 My MJ rear is probably sitting between 3.5" & 4" right now, SOA, with flatter XJ leafs swapped under the MJ main leaf. :hijack: hows the wrap with that setup? Link to comment Share on other sites More sharing options...
jpnjim Posted November 12, 2009 Share Posted November 12, 2009 Jeep is still driveway jewelry at this point, so :dunno: . Even though the MJ rear is lighter than an XJ, I'm leaning towards stiffer springs being necessary, if I was gonna keep it this way. I mostly posted to show you could rebuild the leafs to give less lift than they normally would with a SOA. The XJ leafs, under the MJ main leaf is less than ideal, because the 2nd leaf is a little short, and the whole XJ pack is thin. Adding a single longer leaf above the soft XJ pack could do the trick, or even cutting the eyes off an XJ main leaf, tapering the ends, and using that as your 2nd leaf. Link to comment Share on other sites More sharing options...
Pete M Posted November 12, 2009 Share Posted November 12, 2009 put a cherokee shackle on it, then spring-over. I used to recommend that too, but recently a member here had his XJ shackles invert themselves. :eek: So I've pulled it from my recommendations list. :( Link to comment Share on other sites More sharing options...
