vaquaro Posted November 8, 2009 Posted November 8, 2009 I haven't seen this malady before ? :hmm: ....Driving along , and notice smoke wafting up from the turn /wiper stalk . In a panic, I wiggle the thing around a bit and the smoke stops....a couple days later it was raining , tried to turn on the wipers and they only worked on High , no intermittant or low speed ,as well the wiper "park" function didn't work (had to manually time shutting off at the normal park position ) :dunno: Obviously I'm going to have dig into the steering column which I'm a little intimadated by :( Any experience-tips-advise you guys have would be greatly appreciated :help:
xmeatbagx Posted November 8, 2009 Posted November 8, 2009 Dude my truck did the same thing. It was raining and my wipers were on then I smelled something burning and lost it all except high. I have no idea what happend. Wicked crapy :(
JeepcoMJ Posted November 9, 2009 Posted November 9, 2009 it's more likely the wiper delay module (if you have wiper delay) under the knee board on the driver's side. it's velcro'd and has wires coming into both sides. remove it, plug the wires together, see if everything (but delay) works. I had that happen once and the smoke carried from under the dash up and through the steering column.
vaquaro Posted November 9, 2009 Author Posted November 9, 2009 it's more likely the wiper delay module (if you have wiper delay) under the knee board on the driver's side. it's velcro'd and has wires coming into both sides. remove it, plug the wires together, see if everything (but delay) works. I had that happen once and the smoke carried from under the dash up and through the steering column. I should have clarified , it's a base wiper w/mist not intermittant function (module ) sorry for the mis-info :oops:
bgb27 Posted November 9, 2009 Posted November 9, 2009 Happened to mine after having it one day. Took it out and swapped it for a newer all black plastic one.
Darren Posted November 9, 2009 Posted November 9, 2009 If your column won't stop smoking you could always try giving it the patch.
vaquaro Posted November 9, 2009 Author Posted November 9, 2009 If your column won't stop smoking you could always try giving it the patch. :rotfl2: The Patch didn't work for me , but I'll give a try on the column :cheers:
akamcbird Posted November 12, 2009 Posted November 12, 2009 wow! :headpop: if i get smoke signals.........I'm going to the junk yard! took one apart while trashing an old junker and what that write up is missing is all the broken pieces your guna find bouncing around in that housing
vaquaro Posted November 12, 2009 Author Posted November 12, 2009 :agree: and I expect I'll find some broken piece thats causing a short in there .The good thing is knowing what it supposed to look like in there first :thumbsup:
vaquaro Posted November 24, 2009 Author Posted November 24, 2009 Bought a new wiper switch , plugged it in at the lower column connection block ....Voila !...all works correctly . :D So next week-end I get to tear into the steering column :( to install the new stuff (got a new signal switch too ) Wish me luck :shake:
vaquaro Posted November 30, 2009 Author Posted November 30, 2009 :wall: This project is really going sideways ....nobody ( haynes etc ) mentioned how to access the wiper switch hinge pin/bolt .....So I remove the lock barrel and the 4screws inside the plastic shroud , managed to break the upper one trying to separate the two . :headpop: At least I was able to finally get to the hinge pin and swap in the new wiper switch . Re-assembly didn't go well ,after which the following " New" problem arose ....on start up ,key doesnt spring back to dis engage starter (did it manually ) also the key release lever is stiff/binding :help: Sure could use your input on this :dunno: Thanks , Gord
