Name that Tune in "x" Notes? (Audio of Engine!)
The guys that have been around CC.Com a while have heard me constantly piss and moan about my engine knock and how I need to swap engines, etc.
Since all but a couple of you guys aren't close enough to come help me wrench on the truck, I thought I would record the knock and get the collective opinion of the ComancheClub brethren as to how much I really should worry about this.
The Video isn't important...listen to the audio...
http://www.leishman.net/videos/knock.mp4
Thoughts?
sounds like a 4.0L... if it ain't knockin it ain't running.
seriously though, the machine shop our shop uses' owner has a 4.0 cherokee said it's knocked since brand new, and it now has 200,000 on the clock.
some of them do, some of them don't... i wouldn't worry about it TO much, and know that the potential of a replacement junkyard motor is VERY likely to do the same.
  SuperWade2 said:
  Oizarod115 said:
also if the engine was cold in the video some of that could be attributed to cold slap of the piston.
It was cool'ish, but it pretty much sounds like that all of time, hot/cold or otherwise!
if you have the money/time for an overhaul and don't mind spending it, i see no reason not to. Even without the noise you're hearing, the motor is 20 years old and i'm sure could use going through.
if you're not in the position to overhaul it, or don't want to; i don't see that it's to much to worry about. at this point you could check oil pressure and possibly do a pump, rod bearings and a rear main just dropping the pan which would cover your bottom end and should be easy-ish.
third option would be let it eat til it quits. chances are its been doing it for years and will continue on for years before it goes kaput.
Option 3 is the most realistic in my current position right now...
Sounds like a lifter tapping to me. Is it louder from above the engine or below? I've been told that if it's louder from the top, it's a lifter, and if louder from underneath, it's a rod bearing. I'm not saying that is 100% but makes good sense I guess.
:cheers:
Seafoam quieted mine down for about a week. After that it came back. Lucas seems to work the best. Another problem I've found with 4.0L motors is the rocker arms tend to bend. I've pulled apart the heads on 3 or 4 of these motors(not all driven by me) and two of the four had bent rocker arms that were causing the noise.
Easiest way to find out exactly where the noise is coming from is to take a length of hose and use it as a stethoscope kinda device. One end next to your ear, point the other end at stuff to find noises.
