Scottanchee Posted September 28, 2009 Share Posted September 28, 2009 I am going to be putting a 8.8 in my 88 MJ . I know I have to swap in a prop valve for a rear disc brake setup , but what about the master and boster ? I can get one from a 95 ZJ , Should I swap it in ? Link to comment Share on other sites More sharing options...
MiNi Beast Posted September 28, 2009 Share Posted September 28, 2009 I didn't touch anything on my brakes when did mine, did just fine. Only thing to mess with was the level load valve thing, I just bypassed mine though. Link to comment Share on other sites More sharing options...
FireFighter32 Posted September 28, 2009 Share Posted September 28, 2009 I am interested in doing this swap in the near future also. Any details would be much appreciated. Link to comment Share on other sites More sharing options...
dakineJ Posted September 28, 2009 Share Posted September 28, 2009 Did you guy's use 95' Explorer axles? What kind of prices are peaple finding 8.8's for? Interested in more info on this swap as well. Link to comment Share on other sites More sharing options...
Pete M Posted September 28, 2009 Share Posted September 28, 2009 95-01 are the ones with disks. Older models are also acceptable, but will have drums. I've purchased them for as little as $75 at the pull-a-part, but 200-300 is an ok price if it's in good shape and has the brakes still on it (core charge for the calipers is ungodly high) Link to comment Share on other sites More sharing options...
reson46 Posted September 28, 2009 Share Posted September 28, 2009 Did you guy's use 95' Explorer axles? What kind of prices are peaple finding 8.8's for? Interested in more info on this swap as well. Like Pete said, $75 at pull a parts. I picked one up a few weeks ago for $143 with rotors, calipers, etc. Just the bare axle without the brakes was $75. Willy Link to comment Share on other sites More sharing options...
Pete M Posted September 28, 2009 Share Posted September 28, 2009 also, don't get a 3.73 ratio unless you can find a front to match (or can pay for a regear). 3.73s were a fairly rare ratio in XJ/MJ Dana 30s. They are common in low pinion 30s though (ZJ/TJ), so if you're going to be at stock to 3" of lift, that would work. Link to comment Share on other sites More sharing options...
TrailReadyMJ Posted October 5, 2009 Share Posted October 5, 2009 I too didn't do anything special with the brakes when I did my swap. I just "permanently" adjusted the load sensor to make it think there was more weight back there, thus giving some extra pressure for the discs. Worked just fine, and stops much better than it did with the worn out drums! Link to comment Share on other sites More sharing options...
Tim. Posted October 5, 2009 Share Posted October 5, 2009 i don't know if this will help you 100% because it is geared towards tjs... i started this thread several years ago and it has covered many-many different opinions and ideas... hth tim http://www.jeepsunlimited.com/forums/showthread.php?t=371713 Link to comment Share on other sites More sharing options...
cracker Posted October 5, 2009 Share Posted October 5, 2009 I didn't touch anything on my brakes when did mine, did just fine. Only thing to mess with was the level load valve thing, I just bypassed mine though. So you are driving around without a prop valve? Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 6, 2009 Share Posted October 6, 2009 I didn't touch anything on my brakes when did mine, did just fine. Only thing to mess with was the level load valve thing, I just bypassed mine though. So you are driving around without a prop valve? I was in the rear of the MJ, did not use the level load valve. I wasn't hauling wood either. :thumbsup: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted October 6, 2009 Share Posted October 6, 2009 I didn't touch anything on my brakes when did mine, did just fine. Only thing to mess with was the level load valve thing, I just bypassed mine though. So you are driving around without a prop valve? I did so for a very long time.. no issues what so ever. Every PU I ever had will generally lock rear tires first anyhow. CW Link to comment Share on other sites More sharing options...
