case5412 Posted November 29, 2009 Share Posted November 29, 2009 Great job! That's some nice work. I want your old wood grain interior piece, lol. :brows: :brows: :brows: Link to comment Share on other sites More sharing options...
64 Cheyenne Posted November 29, 2009 Author Share Posted November 29, 2009 I'm not sure if I still have it, if I do, pay shipping and its yours. Edit: Sorry It's gone :dunno: Link to comment Share on other sites More sharing options...
64 Cheyenne Posted December 29, 2009 Author Share Posted December 29, 2009 Got the sway bar drop brackets fixed today, yeah I know, I could have just got extended links for it. It came with the DBs so I figured I'd go with the setup that is already on it. Might have to pull the left side one off if it has clearance problems with the pitman arm. That was pretty much the last of the major underside stuff to be done, got a few other small issues to fix then she'll be roadworthy. I been really wanting a grill guard for it, but seems that cost and distances are keeping me from getting one I want. Oh well, hopefully time and patience will pay off with a good deal in the future. If all else fails I'm thinking of cutting and modifying the one that was on my last TJ to fit. Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found After looking at the pics I'm kind of not sure if the angle of the bar is going to be acceptable or not, tomorrow I'll compare it to one of the other Jeeps. Link to comment Share on other sites More sharing options...
dancome433 Posted December 29, 2009 Share Posted December 29, 2009 Great build man, can't believe you got that thing for only $100, keep up the good work Link to comment Share on other sites More sharing options...
jeeplover88 Posted January 3, 2010 Share Posted January 3, 2010 WOW! 100$ haha thats a steal! I'm liking what you're doing! Nice Job! Link to comment Share on other sites More sharing options...
-600JeepMJ Posted January 3, 2010 Share Posted January 3, 2010 :grrrr: it took me several years to find my MJs...... every time i would find a cheap one some else would get to it first. :wall: at that price you are very lucky to get it. :banana: Link to comment Share on other sites More sharing options...
64 Cheyenne Posted January 11, 2010 Author Share Posted January 11, 2010 Well I'm nearly done enough to make this one a driver. Some of the other things I have done are: fixed the valve cover oil leak, Increased the CC ventilation with larger hose and manifold fittings. Installed a brush guard that I picked up off of CL for $80 delivered. Installed visor $80 off of Ebay. Took the tires off of Megan Joy-87MJ. Removed cleaned and adjusted the throttle body TPS. Dig the visor! I really like the pic above. The back tires now match the fronts, not seen in this last pic. Aw heck I'll just post this: To do list: Fix all wiring- Done Replace slave cylinder- Done Replace transmission- Done Adjust tailgate- Done Fix drivers door hinges- Done Adjust both doors- Done Replace door seals Done Remove, clean, reinstall carpet- Done Fix holes in floor, install bedliner- Done Replace drivers side fender- Done Replace bumper- Done Replace grill- Done Fix head lights, turn sig lights and doors- Done Replace dash- Done Repair headliner- Done Tighten control arm bolts- Done Lock CAD over- Done Remove and plug vacuum lines- Done Rebuild front axles (U-Joints)- Done Rebuild both drive shafts- Done Change engine oil- Done Change F&R diff fluids- Done Tighten spindle nuts- Done Refill trans and TC- Done Fix license plate light- Done Shocks-replaced rears-kept fronts- Done Replace rear bumper- Done Switch tires off of the 87- Done Install starter- Done Replace harmonic balancer- Done Fix battery box- Done New battery (blem) Done Fix sway bar mounts- Done Fix/install back-up light harness- Done Replace battery cables- Done Check coolant protection- Done Change fuel and air filter- Done Fix valve cover- Done Fill engine oil- Done Fix/check vac lines- Done Check alignment, sway bar clearance, center- Done Install brush guard- Done Install visor- Done Inspect brakes- Done Replace broke wheel stud (rear)- Done Fix rearview- Done Install some kind of lights on the grill guard Done Fix speedo cable Done Install new cluster Done Install stereo Done Estimated cash output-start to finish, less than a thousand dollars. can't find my camera, so I'll try and post more pics when I find it. Last but not least, put CC sticker on! Done Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 12, 2010 Share Posted January 12, 2010 sweet good work it looks really good Link to comment Share on other sites More sharing options...
64 Cheyenne Posted January 19, 2010 Author Share Posted January 19, 2010 Well It's done as it is gonna get for now. I'm sure in the future It'll get more. BTW I bought an extra AX-15 and 231 for $125 this past weekend, I'll probably put it in this truck when the BA-10 goes south. Maybe someday It will get paint. Tomorrow, time to cruise. Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 19, 2010 Share Posted January 19, 2010 sweet man Link to comment Share on other sites More sharing options...
Macker72 Posted January 25, 2010 Share Posted January 25, 2010 Any plans to remove the BA-10 alltogether and swap in something a little less French? Missed a post... swap in that spare AX-15 straight away! Link to comment Share on other sites More sharing options...
64 Cheyenne Posted January 25, 2010 Author Share Posted January 25, 2010 Naw.... I'm gonna wait a while before I start anything else on this truck. It is good to know that I have a complete AX-15 for when the time comes, hopefully not too soon. Reason I'm not going to do this swap right away is I just got this truck drivable, want to enjoy it for a while. Another reason is I have a 94 Astro that needs head work taken care of first, and what with school and all it doesn't look like the tranny swap on this MJ is going to happen in the near future........knock on wood....... Plus the other MJ that was supposedly my "primary" MJ project. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 12, 2010 Author Share Posted June 12, 2010 It's been a while since Ive last updated on this truck. I put 31 10 Treadwrights on it and as expected I turned it into a cool looking dog. The gear ratio immediately became unbearable. I knew that if I continued to run it this way, I would eventually need a clutch. Exploder Donor Image Not Found Paid my nephew to pull the turdy five. Prepping the 8.8 for new gears and installation The plan is to reuse the existing spring perches, hubcentric wheel spacers (so I can run the jeep wheels I have) weld shock mounts to the axle. Use the DS I had fabbed for the other truck. While the truck is down, I'm also going to do an AX15 swap (with new clutch assy). I really don't want the Goat making up its own mind on when it is going to fail. For the front axle, I'm taking the D30 out of the XJ (recently stripped-as seen in the photos) rebuild the center section. Put the axles out of the existing axle in it (they're already rebuilt). Then that axle will be regeared with 4.56s, larger one piece axles and a Lock-Right for the 87. Link to comment Share on other sites More sharing options...
reson46 Posted June 14, 2010 Share Posted June 14, 2010 I think the Exploder pictures are worthy of some explanation. :???: Did you just come across a rolled Exploder on the side of a mountain road? :rotfl2: Willy Link to comment Share on other sites More sharing options...
Pete M Posted June 14, 2010 Share Posted June 14, 2010 yes :D viewtopic.php?f=3&t=23204 Link to comment Share on other sites More sharing options...
reson46 Posted June 14, 2010 Share Posted June 14, 2010 yes :D viewtopic.php?f=3&t=23204 Thanks! :thumbsup: Link to comment Share on other sites More sharing options...
UglyAmerican00 Posted June 30, 2013 Share Posted June 30, 2013 I could really use your help on redoing my 88 mj. I'm worried I'm going to screw it up . first thing I want to do is fix the radio and the dome lights. (niether turn on) Link to comment Share on other sites More sharing options...
'87 fuel-miser Posted June 30, 2013 Share Posted June 30, 2013 nice job ! amazing transformation ! :banana: . :MJ 1: . Link to comment Share on other sites More sharing options...
