jeep_freek88 Posted April 19, 2009 Posted April 19, 2009 Ok Well in the process or taking out my wiring harnes....still not done ....... I broke the clip off of my speedometer cable... :fs1: :wall: :headpop: Sooooooo where can I find one I have been looking online for a while and havent called my parts store yet, because I feel like a dumb a$$.................Are they a pain to put in? can I just get the clip at the end and repair the one I have ???????? thanks in advance :wavey: :thumbsup:
jtdesigns Posted April 19, 2009 Posted April 19, 2009 Speedo cables are easy to replace. I got mine at NAPA and it came with a pack of lube and the grommet was installed on the cable already. Took about 20 mins putting it in.
Timmaay Posted April 23, 2009 Posted April 23, 2009 What's all involved in replacing one? I too broke the clip off of mine :doh:
500 MJ Posted April 23, 2009 Posted April 23, 2009 Undo the nut at the Trans. Then loosen it from the retaining clips on the body (if you still have them). Then just take your dash apart and push/pull the cable down through the firewall. Install it in the opposite order, make sure the Nut is tight on the trans end.
jeep_freek88 Posted April 23, 2009 Author Posted April 23, 2009 Ok NAPA can't get it......or my local jeep dealer because it is a cancled part!!!!!!!!!!!!! :fs1: Ok so If anyone has any ideas other than going to a junk yard let me know...... p.s. Part #J5752281 NOS anyone or anyone have one lying around :brows: Hard to find because of my stupid 5 speed trans :headpop: :doh: thanks for the help :banana:
Wildman Posted April 24, 2009 Posted April 24, 2009 Try Rockauto.com DORMAN Part # 03269 {TECHoice #4897799AA} Lower; w/o Cruise Control; RWD * Non-stock item--shipping delayed up to 2 business days $22.79 It don't say if it for a manual or auto tranny :hmm:
jeep_freek88 Posted April 25, 2009 Author Posted April 25, 2009 Try Rockauto.com DORMAN Part # 03269 {TECHoice #4897799AA} Lower; w/o Cruise Control; RWD * Non-stock item--shipping delayed up to 2 business days $22.79 It don't say if it for a manual or auto tranny :hmm: Dorman part #03269 Couldnt find when searching it skipped over that number :???: TECHoice #4897799AA Will not work it has a screw on fitting on both ends and is 65"long Thanks for the help :cheers: any more ideas would be great ......I'm Trying to find one in a junk yard somewhere, but am having no luck so far............HELP Mine has a screw fitting on the tranny end and a plastic snap fitting to the cluster...its 78" long :help:
jeep_freek88 Posted April 25, 2009 Author Posted April 25, 2009 Can I Just run the truck With out the speedo cable?? SWould that cause harm to anything ?? :roll:
Wildman Posted April 26, 2009 Posted April 26, 2009 The only thing that it would really do is not run up the mileage on the odometer, and not show your land speed..........be a great excuse to get out of a speeding ticket......like " I don't know how fast I'm going " :dunno: :brows: Here, I brought up the page, try this- http://www.rockauto.com/catalog/x,carco ... ttype,1440
JeepcoMJ Posted April 26, 2009 Posted April 26, 2009 Ok NAPA can't get it......or my local jeep dealer because it is a cancled part!!!!!!!!!!!!! :fs1: Ok so If anyone has any ideas other than going to a junk yard let me know...... p.s. Part #J5752281 NOS anyone or anyone have one lying around :brows: Hard to find because of my stupid 5 speed trans :headpop: :doh: thanks for the help :banana: what's highlited in bold is BS. they are identical between auto and 5 speed, or at least interchangeable. if you can get one for an auto, grab it. the only difference is whether it's a cruise control or non-cruise speedo cable.
jeep_freek88 Posted April 27, 2009 Author Posted April 27, 2009 The only thing that it would really do is not run up the mileage on the odometer, and not show your land speed..........be a great excuse to get out of a speeding ticket......like " I don't know how fast I'm going " :dunno: :brows: Here, I brought up the page, try this- http://www.rockauto.com/catalog/x,carco ... ttype,1440 Nope Will not work I was just about to complete my order from rock auto on this and :idea: Bam An idea I called rock auto with some questions. Dude said its for a rwd only and will not work on a 4wd.......... :headpop: :wall: Thanks for helping me look though :cheers: Ok NAPA can't get it......or my local jeep dealer because it is a cancled part!!!!!!!!!!!!! :fs1: Ok so If anyone has any ideas other than going to a junk yard let me know...... p.s. Part #J5752281 NOS anyone or anyone have one lying around :brows: Hard to find because of my stupid 5 speed trans :headpop: :doh: thanks for the help :banana: what's highlited in bold is BS. they are identical between auto and 5 speed, or at least interchangeable. if you can get one for an auto, grab it. the only difference is whether it's a cruise control or non-cruise speedo cable. As for you Do you have any productive ideas??? :dunno: The problem I'm having is that every speedo cable I have found does not have the right fitting for the back of the gage......Its not a screw typ fitting its a snap on plastic fitting.....Also the cable off my MJ is 78" long ............Sort af an odd ball..........And its a cancled part from JEEP......... :rant: :fs1: Any help would be great or if anyone has one lying around they want to get rid of would be even better... :cheers: Thanks again :waving:
jeep_freek88 Posted April 28, 2009 Author Posted April 28, 2009 :fs1: :headpop: :mad: Still no luck in my searching ............... :ack: :shake:
Timmaay Posted April 29, 2009 Posted April 29, 2009 :fs1: :headpop: :mad: Still no luck in my searching ............... :ack: :shake: I have the same problem and am thinking about making my own clip or just some other way to hold it on. Half of an alligator clip secured to the cable with a special notch to fit the speedo is the current idea.
jeep_freek88 Posted May 2, 2009 Author Posted May 2, 2009 :fs1: :headpop: :mad: Still no luck in my searching ............... :ack: :shake: I wish I still had that option......When I called napa they said "Oh yeah we have that in stock just come pick it up" So I decided to remove the speedo cable from the truck to bring it in to make sure they were giving me the right one, and to show them the right one so I didn't look like an idiot when I told them it was wrong.........anyway in the process of removing it the white plastic portion seperated from the cable :headpop: so yea now it completly worthless I really need some :help: :cheers: :cheers: :wall: :shake:
maddzz1 Posted May 2, 2009 Posted May 2, 2009 Do XJs use the same type of connector at the cluster end?
