flint54 Posted April 15, 2009 Share Posted April 15, 2009 I think the PO was a bit heavier than me, the outboard side of the drivers seat bottom sags badly. I really want to keep the original seats, since other than the sag, they're in excellent condition. Anyone ever successfully resolve this issue short of replacing the seat? FPM indicates that the driver and passenger bottom are same PN, so I might just "cheat' and swap them. CPD shows the pad and pan assy (PN 55195850) still available at ~$200 bucks, but it's not _that_ bad yet. Comments? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 15, 2009 Share Posted April 15, 2009 El cheapo way: Pull both buckets, pull both seat bottoms. Pull upholstery from each bottom and reverse the upholstery installation on the bottoms. Reinstall seat bottoms using the passengers bottom on the drivers side, and vice-versa. The seat belt retainers on each seat bottom will be correct too. :cheers: Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 15, 2009 Share Posted April 15, 2009 FPM indicates that the driver and passenger bottom are same PN, so I might just "cheat' and swap them. Don, didn't he just say that? :dunno: Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 15, 2009 Share Posted April 15, 2009 Yeah, just wanted to point out to swap the bottom covers too. Prolly could have done that w. less typing. :cheers: Link to comment Share on other sites More sharing options...
james750 Posted April 15, 2009 Share Posted April 15, 2009 I have my bench seat sagging on the left side (probably from the left leg moving constantly up and down to push in the clutch), What would you guys advise about this? Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 15, 2009 Share Posted April 15, 2009 I have my bench seat sagging on the left side (probably from the left leg moving constantly up and down to push in the clutch), What would you guys advise about this? Get an automatic? :dunno: Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 15, 2009 Share Posted April 15, 2009 I have my bench seat sagging on the left side (probably from the left leg moving constantly up and down to push in the clutch), What would you guys advise about this? go on a diet :cheers: Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 15, 2009 Share Posted April 15, 2009 ...the outboard side of the drivers seat bottom sags badly. Get one out of an XJ at the junk yard, you'll only need the bottom pan/cushion. Only four bolts hold it onto the frame. The metal pan on my driver's side was cracked parallel to the frame on the outboard side causing the sag, got one for less than $10 at the local pick-n-pull. I have my bench seat sagging on the left side (probably from the left leg moving constantly up and down to push in the clutch), What would you guys advise about this? I put some plywood between the foam and springs, not the most comfortable on long trips but it was temporary until I got a set of buckets. Link to comment Share on other sites More sharing options...
