jeepalex Posted March 19, 2009 Share Posted March 19, 2009 like it says ok here's the proplem when i put it in 4 low and when i go thru a hole and punch the gas everything the motor,light,radio,everthing cuts of for a second or two and then kick back on whats the proplem help help Link to comment Share on other sites More sharing options...
Wildman Posted March 19, 2009 Share Posted March 19, 2009 Are you driving thru the "Black hole"???? Could be a problem with your voltage regulator. When you punch it, your pulling extra electrical power out of the battery, and it's shutting everything down......how old or what condition is your battery in??? Could be as simple as the battery cables being old and corroded too. Link to comment Share on other sites More sharing options...
Geonovast Posted March 19, 2009 Share Posted March 19, 2009 That or a bad alternator. I don't think any MJs came with a voltage regulator? Link to comment Share on other sites More sharing options...
jtdesigns Posted March 19, 2009 Share Posted March 19, 2009 That or a bad alternator. I don't think any MJs came with a voltage regulator? All alt gotta have some sort of voltage reg.. MJ's are internal. I think.. yeah pretty sure.. Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 19, 2009 Share Posted March 19, 2009 :hmm: You got issues bud! Got any more detials that may help the problem. Link to comment Share on other sites More sharing options...
Geonovast Posted March 19, 2009 Share Posted March 19, 2009 That or a bad alternator. I don't think any MJs came with a voltage regulator? All alt gotta have some sort of voltage reg.. MJ's are internal. I think.. yeah pretty sure.. Yeah that's what I was getting at lol. Can't replace the regulator without replacing the alternator. Link to comment Share on other sites More sharing options...
jeepalex Posted March 19, 2009 Author Share Posted March 19, 2009 the batterys a year old red top and also when i punch it like i said everythinh shuts off 4x4 light,motor,radio everything Link to comment Share on other sites More sharing options...
J B Cuz Posted March 19, 2009 Share Posted March 19, 2009 On older trucks the regulator is built into the case of the alternator. Specifically the Delco design. On newer trucks the with the ND alt the regulator is built into the PCM. J B Cuz Link to comment Share on other sites More sharing options...
