pug Posted March 3, 2009 Share Posted March 3, 2009 Will the 207 bolt up to a ax5. Link to comment Share on other sites More sharing options...
Eagle Posted March 3, 2009 Share Posted March 3, 2009 It should. What year 207, and what year AX5? Link to comment Share on other sites More sharing options...
pug Posted March 4, 2009 Author Share Posted March 4, 2009 I know the tranmission is a 1998. I'm not sure the year of the transfercase. Is there any way to find out what year it is on the tag. thanks Link to comment Share on other sites More sharing options...
mjeff87 Posted March 4, 2009 Share Posted March 4, 2009 yes, the stamped info above the model line should be the build date, month and year format Jeff Link to comment Share on other sites More sharing options...
tallon2064 Posted March 4, 2009 Share Posted March 4, 2009 Not sure about the newer one's but the '86 I had, had a np207 bolted to a ax 5. Don't know if that helps you or not. Just an FYI I guess. Link to comment Share on other sites More sharing options...
pug Posted March 4, 2009 Author Share Posted March 4, 2009 So i take it the 207 is for a 4cyl. Link to comment Share on other sites More sharing options...
Eagle Posted March 4, 2009 Share Posted March 4, 2009 The 207 was the Command Trac (part-time only) transfer case for 1984 through 1986 (or 1986 only, for the MJ). It was used with the 4-cylinder and the V6. I have heard conflicting reports as to whether the 207 was used for part or even all of the 1987 model year, and I haven't crawled under the one 1987 MJ I have to look. It's very similar to the 231, but the oiling isn't quite as good and the low range is 2.6x rather than 2.7:1. The reason I asked about year is that for the 231 and the 242, at least behind the 4.0L Jeep changed the spline for the tranny-transfer case interface from 21 splines to 23 splines as of (IIRC) 1991. If that also affects the 4-cylinder models, a late model AX5 won't mate up with a 207 transfer case. Link to comment Share on other sites More sharing options...
mvusse Posted March 4, 2009 Share Posted March 4, 2009 I have an 87, but it's a 4.0 litre. And it definitely has an NP231 as identified by the little plaque on the transfer case. Link to comment Share on other sites More sharing options...
Geonovast Posted March 4, 2009 Share Posted March 4, 2009 I torched a 207 behind a 2.5, I doubt they put it behind the 4.0. I think it'd be better to just find a 231. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 4, 2009 Share Posted March 4, 2009 np207 was used at least until 1988 behind the ax5 4wd version, however it may have been up to 1991...unsure. after that, the np231 was used. there are long and short output seal variations of the ax5, which determine which input size you need on your trans...I haven't yet taken apart my 1994 ax5 and np231 to find out if this is the long or short, however I can say most of the older ax5's used a long input shaft...meaning you cannot use any short input np231 without some modification. the one thing you must have for sure is an ax5 4WD version of the transmission...you cannot simply bolt a t-case to the 2wd ax5 (or any other cherokee, comanche, or newer jeep). that would require swapping your output shafts (and main gear cluster to a 4wd output shaft) and output housing on the transmission. I'm (temporarily) putting an np242 21 spline short input from a 90 cherokee onto my ax5, but I need to swap out the output housing to the short shaft housing first. I wish I'd done thorough investigation on case numbers before I tore all 4 of the ones I've blown (3 I blew one blown with the truck when I got it) so I could tell you what case means what output...but I didn't :dunno: -Pat Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 4, 2009 Share Posted March 4, 2009 oh...one additional piece of info. the ax5 retained it's 21 spline input it's entire career in the cherokee and comanche...only variation was input shaft length. that information is passed on to me (I forget sources) by several different people...as I say, I haven't yet split my 94 trans and t-case but when I do (in the near future) I will let you know. Link to comment Share on other sites More sharing options...
Eagle Posted March 4, 2009 Share Posted March 4, 2009 JeepcoMJ said: oh...one additional piece of info. the ax5 retained it's 21 spline input it's entire career in the cherokee and comanche...only variation was input shaft length. That's sort of what I was thinking, but I don't have any way to confirm. Thanks for the info. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 4, 2009 Share Posted March 4, 2009 Eagle said: JeepcoMJ said: oh...one additional piece of info. the ax5 retained it's 21 spline input it's entire career in the cherokee and comanche...only variation was input shaft length. That's sort of what I was thinking, but I don't have any way to confirm. Thanks for the info. welcome. I'll have to split that case off the trans before the end of the week and find out to confirm...one more notch to the databanks. Link to comment Share on other sites More sharing options...
Eagle Posted March 4, 2009 Share Posted March 4, 2009 JeepcoMJ said: welcome. I'll have to split that case off the trans before the end of the week and find out to confirm...one more notch to the databanks. Yeah, but we really need to formalize that data bank. Perhaps we need to start a thread in which people can post what year and tranny they have, and what the spline count and length of the shaft is. Mostly we all just sort of vaguely think "21-spline" or "23-spline," and we know that Jeep changed around 1991 (or so) -- except they didn't change the 4-cyl (unless they changed the shaft length), and ... Yeah, a comprehensive compilation of permutations and combinations would be handy for reference. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 4, 2009 Share Posted March 4, 2009 Eagle said: JeepcoMJ said: welcome. I'll have to split that case off the trans before the end of the week and find out to confirm...one more notch to the databanks. Yeah, but we really need to formalize that data bank. Perhaps we need to start a thread in which people can post what year and tranny they have, and what the spline count and length of the shaft is. Mostly we all just sort of vaguely think "21-spline" or "23-spline," and we know that Jeep changed around 1991 (or so) -- except they didn't change the 4-cyl (unless they changed the shaft length), and ... Yeah, a comprehensive compilation of permutations and combinations would be handy for reference. yup. I have no intention of ever messing with tearing ax5's apart again however...so I will not be able to give us an exact year on when they changed the long/short input shaft on the np207 Link to comment Share on other sites More sharing options...
pug Posted March 5, 2009 Author Share Posted March 5, 2009 I got to bolt the 207 to the ax5 (4wd) every thing bolted up allright out off vehichle. Now i heard i have to change the front bearing cover. Because the 98 ax5 is a external slave cylinder. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 5, 2009 Share Posted March 5, 2009 pug said: I got to bolt the 207 to the ax5 (4wd) every thing bolted up allright out off vehichle. Now i heard i have to change the front bearing cover. Because the 98 ax5 is a external slave cylinder. why don't you use the external slave cylinder. because your internal front cover is a different size. it won't bolt on Link to comment Share on other sites More sharing options...
Geonovast Posted March 5, 2009 Share Posted March 5, 2009 JeepcoMJ said: pug said: I got to bolt the 207 to the ax5 (4wd) every thing bolted up allright out off vehichle. Now i heard i have to change the front bearing cover. Because the 98 ax5 is a external slave cylinder. why don't you use the external slave cylinder. because your internal front cover is a different size. it won't bolt on Why not? I have an 86 External Retainer bolted onto a 93 AX-5. IIRC the only thing ever changed in the AX-5 was the size of the input bearing. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 5, 2009 Share Posted March 5, 2009 Geonovast said: JeepcoMJ said: pug said: I got to bolt the 207 to the ax5 (4wd) every thing bolted up allright out off vehichle. Now i heard i have to change the front bearing cover. Because the 98 ax5 is a external slave cylinder. why don't you use the external slave cylinder. because your internal front cover is a different size. it won't bolt on Why not? I have an 86 External Retainer bolted onto a 93 AX-5. IIRC the only thing ever changed in the AX-5 was the size of the input bearing. oh. perhaps I confused the ax5 and ax15 bearing retainers? Link to comment Share on other sites More sharing options...
Eagle Posted March 5, 2009 Share Posted March 5, 2009 Geonovast said: Why not? I have an 86 External Retainer bolted onto a 93 AX-5. IIRC the only thing ever changed in the AX-5 was the size of the input bearing. I have an 88 4-cyl with an AX4 tranny that has an internal slave. I'm sure the AX5 was the same setup. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 5, 2009 Share Posted March 5, 2009 Eagle said: Geonovast said: Why not? I have an 86 External Retainer bolted onto a 93 AX-5. IIRC the only thing ever changed in the AX-5 was the size of the input bearing. I have an 88 4-cyl with an AX4 tranny that has an internal slave. I'm sure the AX5 was the same setup. yes, but the only difference between the internal and external bearing retainer plate is that it's got a sleeve on it that covers the input shaft about 3" and allows the throwout bearing to slide on it. OP leave the external slave assembly and set it up for external....you will be WAAAAY happier to replace it when it fails, than having to yank your trans to do it. Link to comment Share on other sites More sharing options...
