genorater Posted February 7, 2009 Share Posted February 7, 2009 i have a 1989 jeep comanchee and it has the 4.0 liter strait 6 4x4 5 speed and it runs very well but sometimes it will just stall no matter the speed the motor will just die i ll have powerto everything but the motor and getting started again is very hard it is fuel injected but i still have to pump the gas to get it going and when i do get it going it will rev at about 3500 rpm for about 10 seconds someone please help me Link to comment Share on other sites More sharing options...
Randy in Maine Posted February 7, 2009 Share Posted February 7, 2009 Have you checked the fuel pressure? With and without the vacuum line to the pressure regualtor please. Link to comment Share on other sites More sharing options...
Eagle Posted February 7, 2009 Share Posted February 7, 2009 I'm thinking Idle Air Controller (IAC) Link to comment Share on other sites More sharing options...
bigd44889 Posted February 7, 2009 Share Posted February 7, 2009 :agree: with both Link to comment Share on other sites More sharing options...
genorater Posted February 7, 2009 Author Share Posted February 7, 2009 and what is that Link to comment Share on other sites More sharing options...
james750 Posted February 7, 2009 Share Posted February 7, 2009 The idle air controller (IAC) is a stepper motor that changes the airflow based on the conditions to keep the engine idling smoothly. You should pull it and clean it and if it still doesn't work replace it. The IAC is located to the left of the TPS (Throttle position sensor) on the throttle body. Link to comment Share on other sites More sharing options...
Pete M Posted February 7, 2009 Share Posted February 7, 2009 Link to comment Share on other sites More sharing options...
genorater Posted February 8, 2009 Author Share Posted February 8, 2009 i have already replaced that . today i also did an oil change and put in a new fuel filtter and put in a complete fuel system cleaning agent to my gas . the old fuel filtter had some restriction when i blew through it so that my have been the problem but if not i have no idea hahahaha the more feedback i get the better and thanks guys Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 8, 2009 Share Posted February 8, 2009 I was thinking TPS because of the need to step on the accelrator pedal to start. CLICK HERE for the testing & adjustment procedures Link to comment Share on other sites More sharing options...
genorater Posted February 8, 2009 Author Share Posted February 8, 2009 sweet thanks i ll try that and if nothing changes i ll be sure to get back to you :Canadaflag: Link to comment Share on other sites More sharing options...
genorater Posted February 8, 2009 Author Share Posted February 8, 2009 ok i replacer the idle speed stepper motor and the throttle postion sensor and it is still stalling out :grrrr: don't no what else it could be if enyone else has eny other ideas please let me know thanks Link to comment Share on other sites More sharing options...
aaronsh2rcvry Posted February 9, 2009 Share Posted February 9, 2009 crank sensor Link to comment Share on other sites More sharing options...
genorater Posted February 9, 2009 Author Share Posted February 9, 2009 and how do i get at that without droping the tranny :dunno: Link to comment Share on other sites More sharing options...
