Dash Clock
I'm soon planning on putting in one of those factory XJ dash clocks in my MJ. Behind the blank panel that all of comanches came with, is the plug already there or do you have to do some sort of wiring to make the clock work??
Please tell me the wires are back there and its just a plug and chug deal!!! :D
I actually just pulled the big dash piece out, and I didn't really see anything that looked like a plug. There was however a bunch of three wires, two of which went to the cig lighter, the other wire just ran into an end plug that was just laying in there. Is that the connection for the clock or something else??
Tomorrow morning I'll be pulling the donor clock from a 91 XJ and then hopefully tomorrow night I'll have time to ATTEMPT at putting it in.
Thanks :cheers:
Thanks :cheers:
If you're pulling from the donor XJ, just take note of the wiring, it will be the same for your MJ.
