are my springs bad
Measure from the center of the hubcap straight up to the bottom edge of the flare. The dimension should be about 20-1/2". If you're within a half inch of that either way, your springs are okay.
[EDIT]Where's that dunce smiley again? I just realized this is a lifted truck, so the 20-1/2" dimension doesn't apply. You wrote AAL but I was thinking of the factory overload leaf. Yeah a gap like that is pretty common when you use a short AAL to bend the spring into an unnatural shape. I would strongly advise you to find some way to get rid of the short AAL, it isn't helping your springs at all.
I've got a long AAL in the rear of my MJ, I don't have the gap, and the sprigs seem none the worse. It doesn't flex for crap though. I think I'm going spring over in the rear next summer and going back to stock spring packs.
