wolfpackjeeper Posted January 11, 2009 Posted January 11, 2009 Anyone get one to fit reasonably. I picked one up from the JY for 3 bucks just in case. I think I could either redo the headliner and cut out a strip in the middle to mount it, or possibly just trim the back of the sound bar to make it fit. Wondering if anyone has some insight. I want 2 more speakers in the MJ, but I do not have the mounts (or wiring from what I can tell) to put them behind the seats. Plus when I add a sub back there a lot of sound will be getting blocked.
BookspanS Posted January 11, 2009 Posted January 11, 2009 I have a slim 12 in the back of my truck, and there is still some space between the side of the box and where the b-pannel speaker grill is
wolfpackjeeper Posted January 11, 2009 Author Posted January 11, 2009 yea, I figure that the stock location would work, just wondering if the sound bar was an applicable idea or not. I have it in my cherokee right behind the front seats and I really liked it.
BookspanS Posted January 11, 2009 Posted January 11, 2009 And when you wire an amp for the sub, you can easily hide the wires behind the drivers side trim (under the trim under the kicker panel, then straight back to the b panel) i then just drilled two holes for the power and remote power :hijack:
wolfpackjeeper Posted January 11, 2009 Author Posted January 11, 2009 yea, all that is easy. I usually run power down one side and the remote and RCAs down the other side. Once I actually road trip back up to get my cherokee from NC I will probably just swap all the wiring to the MJ.
jtdesigns Posted January 11, 2009 Posted January 11, 2009 Think it would fit on the back panel behind the seat?
wolfpackjeeper Posted January 11, 2009 Author Posted January 11, 2009 hmm, below the plastic trim from the window, where the carpeted panel is supposed to go? I had not thought about that. Could work out well, especially if I end up making a back panel since I cannot find one. I could just incorporate it into the panel I make.
BookspanS Posted January 11, 2009 Posted January 11, 2009 yea, all that is easy. I usually run power down one side and the remote and RCAs down the other side. Once I actually road trip back up to get my cherokee from NC I will probably just swap all the wiring to the MJ. Its bad to run any power line and the audio near each other
wolfpackjeeper Posted January 11, 2009 Author Posted January 11, 2009 yea, all that is easy. I usually run power down one side and the remote and RCAs down the other side. Once I actually road trip back up to get my cherokee from NC I will probably just swap all the wiring to the MJ. Its bad to run any power line and the audio near each other It can give you some interference issues sometimes. I usually run them apart. Some do not see a difference, some do. I just run them separate, it is not that much harder.
wolfpackjeeper Posted January 12, 2009 Author Posted January 12, 2009 after looking around a lot today I do not see a very reasonable way to fit one in. It will be easier to fit them behind the seat, into the lower dash, stock location, ect than to try to get them into the headliner. Even with the soundbar.
jtdesigns Posted January 12, 2009 Posted January 12, 2009 Whats it made from? You might be able to cut it kinda like Shelbyluv did a overhead console and weld it back together with a bit of filler if its plastic.. I have one in my XJ but I've never removed it, or really ever checked it out.
wolfpackjeeper Posted January 12, 2009 Author Posted January 12, 2009 Whats it made from? You might be able to cut it kinda like Shelbyluv did a overhead console and weld it back together with a bit of filler if its plastic.. I have one in my XJ but I've never removed it, or really ever checked it out. It would be doable that way, but the problem is the way that the back of the headliner in the cab rolls down. I may try to work on it more, but if so I will go snatch a new headliner backing from the JY and mold it to that. It is a dense foam type plastic.
rmoore1031 Posted May 1, 2013 Posted May 1, 2013 Bringing back an old thread instead of making a new one. Anyone in the last few years put the XJ soundbar in a MJ? I'm thinking of a 97+ XJ soundbar. I don't care about how wires look, as long as it sounds louder than stock.
noboundaries.jd Posted May 1, 2013 Posted May 1, 2013 ive been pondering that same idea. pulled enough of the trim from a 2001 a couple of weeks back to be able to see behind it. i don't see why it would be a problem as long as you arent hoping to salvage your current headliner fabric. you will absolutely need a bit more fabric to stretch over the soundbar. unless you pull the whole headliner i would cut it at least 1 1/2 feet in front of the speakers, pull your current MJ headliner, remove fabric from both and fit soundbar to MJ backer. cover with new fabric, run speakers leads and power for lamp and reinstall.
rmoore1031 Posted May 1, 2013 Posted May 1, 2013 ive been pondering that same idea. pulled enough of the trim from a 2001 a couple of weeks back to be able to see behind it. i don't see why it would be a problem as long as you arent hoping to salvage your current headliner fabric. you will absolutely need a bit more fabric to stretch over the soundbar. unless you pull the whole headliner i would cut it at least 1 1/2 feet in front of the speakers, pull your current MJ headliner, remove fabric from both and fit soundbar to MJ backer. cover with new fabric, run speakers leads and power for lamp and reinstall. That's pretty much my theory too lol. My headliner has no fabric on it so I'll have to redo the fabric in the future anyway.
88whitemanche Posted December 31, 2014 Posted December 31, 2014 Anybody ever complete this? Best one to use is the pre 96 xj sound bar... Because the 97+ is molded to the headliner.... I never really got around to installing mine but if you do go that route it's the easier option....
dasbulliwagen Posted January 1, 2015 Posted January 1, 2015 I pulled one too during cash for clunkers. I've yet to do anything with it because my headliner is actually nice still. Maybe someday I'll see what it takes to mount it up.
