Catatonic Comanche Posted January 4, 2009 Share Posted January 4, 2009 What is the BEST glue for re-attaching "Comanche" logos, "Jeep" letters, "4x4" logos and the "4.0 High Output" logo? I was considering using "Mighty Putty". Any advice would be greatly appreciated. Also, any advice of aligning those "Jeep" letters for re-gluing would be gratly appreciated. V/R :cheers: Paul Link to comment Share on other sites More sharing options...
djag12 Posted January 4, 2009 Share Posted January 4, 2009 Double sided trim tape. Can get it at advanced auto. To align them if you have a magnet you can use as a straight edge guide. Link to comment Share on other sites More sharing options...
jtdesigns Posted January 4, 2009 Share Posted January 4, 2009 3M. Link to comment Share on other sites More sharing options...
james750 Posted January 5, 2009 Share Posted January 5, 2009 I would use a good double sided tape like the 3M with a foam carrier. Last time I used Lord adhesive which worked a little too well and ripped all the paint off on that part of the fender when I removed them. :oops: Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 5, 2009 Share Posted January 5, 2009 Also, any advice of aligning those "Jeep" letters for re-gluing would be gratly appreciated.That's the beauty of the pre-91s, they're held in by pins & sheet metal nuts so the header is drilled, can't misalign them. I would put painter's tape down as a straight edge guide, I don't think a magnet will work, the header is fiberglass/plastic and the letters are non-ferrous (at least mine are). I used 3M trim adhesive tape as stated above for the other emblems and it works great (nice and clean) and looks great. It comes in a variety of widths so take your emblems with you. Link to comment Share on other sites More sharing options...
