Need some help on fenderflares!!
I have extra comanche fender flares. And i always thought that they were nifty looking. And thats what i love in the jeeps. But recently i got a 1992 Ford Explorer 4 door. And the edges of the fenders and quaters around all of the wheel wheels are rotted. So what i plan on doing is shaving all fenders and quauter wells. And i just wanted to know if the comanche plates would fasten to that if i did it the right way. And if any one has ever done this with the comanche fenders on any other vehicle? thanx jamminz.gif
I don't think it will work. I believe early explorers have quite a large fender opening up front. measure in plenty of places first.
it will be hard to tell since the explorer has a round opening and the jeep a more square. but like a said i don't think it will work.
  • 3 weeks later...
Ok OK i went out and put the fender flares up to the ford and looked at it. And pondered... Its going to need alot of shaving. And also the the real quarters of the ford are very close to the door so I'm not going to be use the full fender flare i will have to cut that. Also i will neend to make a new skid plate for mine are rotted out. "Will keep updates on progess.
mr.bigbock
MJ flares can be raised as needed. Front XJ flares are the same size. Gaps can be filled by adding a piece of another flare to the flare you are using. I have played around with MJ/XJ flares and it amazed me how well it looks.
Here is an idea of what can be done on a MJ. :brows:
Side view
Image Not Found
Fit at front body line
Image Not Found
Fit at rear bodyline and filled gap
Image Not Found
Tire coverage with 33x10.50-15 on 15x7 rims with 4" of backspacing
Image Not Found
Another view showing the 11" of clearance over the 33" tire with 6" of lift
Image Not Found
Here are some pictures of what can be done to the rear of a XJ.
Image Not Found
Image Not Found
Image Not Found
Here is a picture of a front flare I only raised to the first body line.
Image Not Found
Here is some pictures of how I fill the gap.
Large
[/img]
Image Not Found
Small
Image Not Found
Image Not Found
I found MJ/XJ flares are easy to work with.
I would think they can be adapted to work on an Explorer.
:cheers:
