manche Posted December 11, 2008 Share Posted December 11, 2008 antidisestablishmentarianism ratio came on the dana 35 rear on a 89 jeep comanche 2.5l ax-5 RWD the reason i want to do a 4x4 conversion but i need to to know the ratio thus if i need to upgrade to match the front diff any suggestions on a front end or antidisestablishmentarianism would be a good axel :???: Link to comment Share on other sites More sharing options...
bigd44889 Posted December 11, 2008 Share Posted December 11, 2008 not sure but mine is 2.5/4speed it has 4:10 if u pull the cover and look at the ring gear it will be stamped on it or mark it and count the teeth Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 11, 2008 Share Posted December 11, 2008 antidisestablishmentarianism ratio came on the dana 35 rear on a 89 jeep comanche 2.5l ax-5 RWD That should be a 4.10, but you will need to physically check it to be sure because nothing is set in stone with these trucks :yes: Link to comment Share on other sites More sharing options...
HKB3 Posted December 12, 2008 Share Posted December 12, 2008 btw it is AXLE :smart: :waving: Link to comment Share on other sites More sharing options...
Geonovast Posted December 12, 2008 Share Posted December 12, 2008 not sure but mine is 2.0/4speed it has 4:10 if u pull the cover and look at the ring gear it will be stamped on it or mark it and count the teeth 2.0? There was never a 2.0 litre motor available in a manche. Smallest was a 2.1L, and that's a turbo diesel. As far as your axle ratio, yes it should be 4.10, which typically came with a 2.5 and 5 speed. If you're just doing a 4wd conversion and no big lifts, you're going to want to find yourself a Dana 30, which are freakishly easy to come by. Any front end parts you'll be able to steal off of an XJ. Everything up front is the same between the XJ and MJ. Link to comment Share on other sites More sharing options...
bigd44889 Posted December 12, 2008 Share Posted December 12, 2008 typo been fixed Link to comment Share on other sites More sharing options...
manche Posted December 12, 2008 Author Share Posted December 12, 2008 so antidisestablishmentarianism ratio :hmm: if i do a 5'' lift antidisestablishmentarianism do i need Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 12, 2008 Share Posted December 12, 2008 so antidisestablishmentarianism ratio :hmm: if i do a 5'' lift antidisestablishmentarianism do i needYou need to know what size tire you are going to run to figure that out ;) . If you are going with 33's, you will likely want 4.56, but if you go 35's then 4.88 would be better with a 2.5L engine. If you have a 4.0L then it would be 4.10 for 33's or 4.56 for 35's. Link to comment Share on other sites More sharing options...
Pete M Posted December 13, 2008 Share Posted December 13, 2008 Factory ratios were generally: 2.5L + 4speed manual = 3.55 2.5L + 5speed manual = 4.10 Please please don't put 35s on a Dana 35 and don't sink any money into regearing it. That axle is simply not worth it. :( Link to comment Share on other sites More sharing options...
