I went out this morning to hed out to work and my jeep wouldnt start I am pissed I havent started it since last friday. It has power
Has anyone had similar problems
I think it may be my starter if so the replacement should be pretty easy
Need some input thank guys
Define "no start" for us. Does it crank but not turn over, or is it dead? If dead, I'd check battery terminal connections. If the starter won't engage, give it a tap or two with a blunt object and try again. If it cranks but won't turn over, try unplugging and replugging the CPS connector.
Jeff
Corrosion in the battery cables or at their ends is a common no-crank cause. It's very frustrating too, as there will be 12 volts as measured at the starter, but not enough juice flows to get the starter turning.
THANKS for the replies guys
POUNDED on the starter for like ten minutes
Charged My battery Started right up
That was last night
Came out this morning and the battery was dead
Which means I got a leak some where
Any Common places to check???????
A neat little trick I learned once for tracking down a short is to pull each fuse and check the circuit with an amp meter. Be sure that you don't have anything running at the time (like the interior light cause the door
is open).
STill looking for the leak decided I drank to much last night to really be playing with electricity
Especially since right when i started it began to rain. Texas weatherman suck. I will began a big project this weekend. and I will document everything. PICS WILL BE COMING FROM THIS
For future reference to anyone
POUNDED on the starter for like ten minutes. Charged My battery Started right up
Happened to me twice now; now I carry a hammer; usually it only takes me two to three good pounding (less than a min) on the starter, and she starts up again. Will eventually replace it. But for now, have other priorities.
Came out this morning and the battery was dead. Which means I got a leak some where. Any Common places to check???????
Back track and look over your last install involving electrical. I did this to solve another no start problem of mine (diff problem from needing to pound the starter).
Turned out to be break in the wire I used to install my ARB compressor. Bare wire was touching ground in the engine bay and causing the battery to drain. Anyhow, I replaced the wire; now I am good to go!
Good luck finding your electrical gremlin. C yah!
I found it Thanks to my wife getting in the passenger seat for the first time in like 2 months she hates my truck. But she looks and see's that my light in my glove box is on with it shut
I screamed FN AY. So that was it no starter or battery problems just that light i tell you what i hate getting caught up in something and over looking the easy stuff.
YEah so that is my story
THX for all your help guys
Oh yeah i solved the problem I superglued a peice of plastic to press the switch when shut works like new
I took my passenger side seat out 2 months ago and havent put it back in cause the wife will sit at home before she gets in the MJ. :nuts: Congrats on finding the prob sometimes you just get to much into mechanics and overlook simple problems, We've all done it.
Cole
