It's not the DeathWobble..
I have been told that it's the Control arm bushings.
Need some other opinions.
Get on the freeway here. drive.. all is cool.
Get off the freeway go from 60ish.. apply brakes and I get the WTF Wobble. If I shift to 4th.. let the clutch out and apply brakes to about 30.. then clutch in and neutral and brake.. I am fine.. but without the downshift.. WTF Wobble is nasty.. bounces the front end nicely.
So.. Opinions.
I agree, you have a couple things going on at the same time. I would first replace/check those rotors. You may in fact be correct with the bushings, but the rotors is where I would begin my search....
CW
I'm a little confused. I believe you indicated it happens when you brake, but then reference downshifting...does it occur more violently when you downshift? if so, I might look at the motor mounts first...
was late.. so maybe not clear
Slowing down from 65mph if I just press the clutch and the brakes brakes I get violent shake in the front end.
Slowing from 65 if I put it in 4th gear and with the clutch engaged I press the brakes I get no shake
so with transmission engaged no shake without the transmission engaged I get a hell of a nasty shake.
I can compensate for it by downshifting. Really would like to just know what it is.
On a side not. At regular surface street speeds (30-45 here) I can disengage the transmission and press the brakes and there is NO WOBBLE. (thus why I think it's the bushings)
does it shake at all when driving down the road? cause my control arm bushings were bad and it would shake at around 40mph then go away at 50mph, and it would shake no matter what when braking.
tranny torque mount? you can use a dial indicator and check your rotors. .005 is spec and minimum thickness is .89 and .86 (4wd/2wd). you can take a jack and start jacking up joints and see what ones crush. personally, i had this problem with my truck. i put a new axle in it (fried pinion bearings) and it went away. blew the steering stabilizer, it came back. so there is a really a long list of things. just start checking them all and ask us if you have any questions. image_209027.gif
Could even be a bad U joint some where in the drive train. But I would start by inspecting the front suspension components. Look at them, feel them, try to move them by hand.
