Skid Plate for Transfer Case
I also have an XJ transfer case skid on my MJ. If your truck didn't come with skid plates from the factory, the frame and cross member do not have the nutserts for the bolts, but the holes are there. I just used short 5/16 bolts with nylon lock nuts instead. Nutserts are not expensive, but the tool to put them in is.
I have 50 extra nutserts or rivetnuts so I got that covered and found a website on how to make the tool for about 2 dollars. So I'm off to the junkyard tomorrow and get an XJ and see how it goes.
Please post the site for the homemade $2 nutsert tool. :D
Thanks.
Got caried away later with the welder checking voltage but here is the tool. All I did then was put a bolt through the tool (nut was larger then bolt - I even bored it out smooth) and then just screw the nutsert on. Hold the tool level and tight and tighten the bolt to expand the nutsert.
Image Not Found
