jeepaholic Posted June 28, 2006 Share Posted June 28, 2006 I have found a MJ that has Chrysler 8.25 rear and dana30 front. 3:55 gears..Anybody ran this set up? Wondering if it is worth a darn. Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 28, 2006 Share Posted June 28, 2006 Depends what year chyrsler axle it has. Early ones were weak like the D35. Link to comment Share on other sites More sharing options...
jeepaholic Posted June 28, 2006 Author Share Posted June 28, 2006 DirtyComanche said: Depends what year chyrsler axle it has. Early ones were weak like the D35.its out of a 92 cherokee..also what was the most common transmission that came in the 88 MJ's..4.0L 4wd? :roll: Link to comment Share on other sites More sharing options...
87manche Posted June 28, 2006 Share Posted June 28, 2006 92 will be the weaker 27 spline variant. It can be made 29 spline with new shafts and carrier. So if you order a detroit or something for it go 29 spline and get shafts to match. There were 3 trans behind the 4.0 All autos are AW4's Early 4.0 87 to mid 89'ish were BA-10/5's. These have a case split from front to back. from mid 89 until the end of production it was the AX-15 5Spd, these are put together with an intermediate plate, and don't have a big seam running front to back. The AX-15 is a much better trans. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted June 28, 2006 Share Posted June 28, 2006 I ran a D30/8.25 3.55 in my '88 MJ with no problems, 6" of lift and 32" swampers. Link to comment Share on other sites More sharing options...
jeepaholic Posted June 28, 2006 Author Share Posted June 28, 2006 That sounds good :banana: This one has 8" lift and i was thinking of running 33 tsl's or Hawgs. Link to comment Share on other sites More sharing options...
JOMJ87 Posted June 29, 2006 Share Posted June 29, 2006 33s May look to small but thats my opinion> I have 7" of lift on 35s and i put a set of 33 14.50 on it and they looked to little for me. But other people may like that kind of look. Post up some pics when you get it. Cole Link to comment Share on other sites More sharing options...
jeepaholic Posted June 29, 2006 Author Share Posted June 29, 2006 JOMJ87 said: 33s May look to small but thats my opinion> I have 7" of lift on 35s and i put a set of 33 14.50 on it and they looked to little for me. But other people may like that kind of look. Post up some pics when you get it. Cole Hold the phone...Uhh i just got my hands on a set of Goodyear Wrangler M/T's 36's..0miles yes 0miles...for free :banana: So if they will fit under there w/o rubbing baby got a new pair of shoes :banana: Link to comment Share on other sites More sharing options...
jeepaholic Posted June 29, 2006 Author Share Posted June 29, 2006 Correction...they are 36x12.50-16.5 Wrangler R/T II's....now i just gotta find some wheels. Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 29, 2006 Share Posted June 29, 2006 They'll fit, just you'll need to use a wheel with a low BS (3.5" or less) if you want to be able to turn. Link to comment Share on other sites More sharing options...
feerocknok Posted June 30, 2006 Share Posted June 30, 2006 Are those Hummer tires? Link to comment Share on other sites More sharing options...
JOMJ87 Posted June 30, 2006 Share Posted June 30, 2006 If You have stock 30/35 axles you may want to get some spare shafts for the rear and stronger u-joints for the front. You also want to beef up the steering cause ive seen the arms bend in half and the box rip off the frame with 36s on a XJ And ive heard of this happening several times to people. Cole Link to comment Share on other sites More sharing options...
pingpong Posted June 30, 2006 Share Posted June 30, 2006 They sound like Hummer tires to me. I don't thing yo can make 36's fit w/o some serious body mods :nanner: Link to comment Share on other sites More sharing options...
JOMJ87 Posted June 30, 2006 Share Posted June 30, 2006 With 7 inches i fit 35s but i couldnt turn or flex to much. I did alittle cutting :D and everything turned out great so 36s will probaly need the same amount of cutting and around 8.5" or more of lift. Cole Link to comment Share on other sites More sharing options...
pingpong Posted June 30, 2006 Share Posted June 30, 2006 Just remove more metal and getting less back spacing on your rims :brows: I am going to ruin 37's on Pong here soon... with no more hieght added. In fact I might lower Pong an inch or 2 :nanner: Link to comment Share on other sites More sharing options...
