88mjmanche Posted November 6, 2008 Posted November 6, 2008 what is the legal ( bottom of the door frame to ground ) in inches can my truck be. I live in MASS. soooooo HELPPPPPPPPPPPPP :help: :drool: :wall:
88mjmanche Posted November 6, 2008 Author Posted November 6, 2008 what is the legal ( bottom of the door frame to ground ) in inches can my truck be. I live in MASS. soooooo HELPPPPPPPPPPPPP :help: :drool: :wall:
pingpong Posted November 6, 2008 Posted November 6, 2008 Check on google... I am sure not everyone memorises lift laws from around the country :help:
88mjmanche Posted November 6, 2008 Author Posted November 6, 2008 yea I'm on google but i don't no what to look for :wall:
89eliminator Posted November 6, 2008 Posted November 6, 2008 http://www.roughcountry.com/lift_laws.html
BLHTAZ Posted November 6, 2008 Posted November 6, 2008 http://www.roughcountry.com/lift_laws.htmlAccording to that it would be 3" lift for MA.. Their formula says that a 2" lift and 2" larger tires = 4" total lift over stock ... someone needs to educate them a little on that. A 2" lift & 2" larger tire would = 3" total lift over stock...
89eliminator Posted November 6, 2008 Posted November 6, 2008 but, depending on the height of lift your going with, MJ's don't look that high when lifted. I'm lifted 6.5in with 33s and its about the height of a stock fullsize truck. i would think that you could get away with pretty much any reasonable lift (i.e. 8in or lower)
xjcrazy09 Posted November 6, 2008 Posted November 6, 2008 OK, so i have made my decision. After reviewing all 50 states lift laws, the only state in the country that will allow anything is Kentucky. So I'm moving to Kentucky :D
89eliminator Posted November 6, 2008 Posted November 6, 2008 OK, so i have made my decision. After reviewing all 50 states lift laws, the only state in the country that will allow anything is Kentucky. So I'm moving to Kentucky :D north dakota and wyoming as well :hijack:
Randy in Maine Posted November 6, 2008 Posted November 6, 2008 Well this will get you started..... From 540 CMR 4.04 (13) Altered Vehicle Heights. The original manufacturers specified height of motor vehicles with an original manufacturers gross vehicle weight rating of 10,000 pounds or less shall not be altered by elevating or lowering the chassis or body by more than two inches, except that four-wheel drive motor vehicles with a original manufacturer's gross vehicle weight rating of 10,000 pounds or less may be altered in accordance with the provisions of 540 CMR 6.00. The Registrar may periodically provide approved altered vehicle height specifications for said four-wheel drive vehicles. Any motor vehicle altered, modified, or changed beyond the aforementioned two inches, or the Registrar's approved altered height specifications, shall be rejected.
Eagle Posted November 6, 2008 Posted November 6, 2008 http://www.roughcountry.com/lift_laws.htmlAccording to that it would be 3" lift for MA.. Their formula says that a 2" lift and 2" larger tires = 4" total lift over stock ... someone needs to educate them a little on that. A 2" lift & 2" larger tire would = 3" total lift over stock... You're not looking at the formula, you're looking at an example. The formula is wheelbase x track / 2200. The example says it might be possible under that formula to qualify a 4" lift of which 2" comes from the body/suspension lift and 2" comes from larger tires.
mvusse Posted November 6, 2008 Posted November 6, 2008 Well this will get you started..... From 540 CMR 4.04 (13) Altered Vehicle Heights. The original manufacturers specified height of motor vehicles with an original manufacturers gross vehicle weight rating of 10,000 pounds or less shall not be altered by elevating or lowering the chassis or body by more than two inches, except that four-wheel drive motor vehicles with a original manufacturer's gross vehicle weight rating of 10,000 pounds or less may be altered in accordance with the provisions of 540 CMR 6.00. The Registrar may periodically provide approved altered vehicle height specifications for said four-wheel drive vehicles. Any motor vehicle altered, modified, or changed beyond the aforementioned two inches, or the Registrar's approved altered height specifications, shall be rejected. Do you have access to 540CMR 6.00? It refers to that section for 4wd vehicles.
jbhill Posted November 6, 2008 Posted November 6, 2008 it can be whatever u want till you get caught. who says they know what it is stock?
BLHTAZ Posted November 7, 2008 Posted November 7, 2008 http://www.roughcountry.com/lift_laws.htmlAccording to that it would be 3" lift for MA.. Their formula says that a 2" lift and 2" larger tires = 4" total lift over stock ... someone needs to educate them a little on that. A 2" lift & 2" larger tire would = 3" total lift over stock... You're not looking at the formula, you're looking at an example. The formula is wheelbase x track / 2200. The example says it might be possible under that formula to qualify a 4" lift of which 2" comes from the body/suspension lift and 2" comes from larger tires. ...but, using their formula, an MJ would qualify for a 3" lift... right? A 3" lift by their formula would be a 2" lift and 2" larger tires unless I am just completely not getting what they are saying. I'm seeing this... LWB - 120 x 58 / 2200 = 3.16" SWB - 113 x 58 / 2200 = 2.97" So no matter if it is short or long bed...3" is the MA limit according to that formula. Now...how often is it likely that they are going to get out there and actually figure out what "stock height" is and check to see if you are within spec?? :dunno:
